LinkBack (1) | Thread Tools |
#1
Need Help With Tie Rods...
replacing inner and outer... i got to the inner removed the dust boot. and now i cn;t get the inner to loosen up... is there a special tool or something to get these off.. i was using an adjustable wrench... let me kno... thnx alot guys
Yes there is a special tool. Too bad you don't live in Wisconsin....
so all i need is the tool and it should come right off correct?
where can i get the tool from.... and what does it look like... thnx
You should be able to get one anywhere.
Here is an example of what one looks like:
thnx man ur a life saver.... gunna go get one after work today i'll let you kno how it works out...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/79541-need-help-tie-rods.html
| Need Help With Tie Rods... | This thread | Refback | July 11th, 2008 11:00 PM | |
Threads Similar to: Need Help With Tie Rods...
| Changing inner tie rod.... | new 5.0 | 94-95 | 0 | June 2nd, 2008 09:31 PM |
| tie rod | zinc02GT | 99-04 | 3 | May 12th, 2008 01:23 AM |
| Tie Rods? | MustangMatt96GT | 96-98 | 38 | April 20th, 2007 09:41 PM |
| Tie Rod Replacement | 00SoSlow | General Tech | 7 | August 9th, 2006 07:42 PM |
