mustang.....aghhh
Old July 9th, 2008, 11:34 PM   #1
The Razor's Edge
White Thunder's Avatar
mustang.....aghhh
im just bored
motors
351w
302w
ls1
trans
t56
t5
clutch
flywheel
bellhousing
body
87-93 notch
87-93 hatch
79-86 but with upgraded body parts
lugs/brakes
5lug
4lug
disk all around
suspension
front k member
4 link
coil overs
adjustable shocks
air bag
exhaust
headers
x pipe
mufflers
founder of the FTN Club
Old July 9th, 2008, 11:36 PM   #2
The Razor's Edge
i would love a
notch
LS1
t-56
Old July 9th, 2008, 11:43 PM   #3
1992 Lx
11.39@119.24
Originally Posted by White Thunder View Post
i would love a
notch
stroked 351 to a 408
t-56
looks perfect
Old July 9th, 2008, 11:46 PM   #4
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
+1 ^
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old July 10th, 2008, 12:17 AM   #5
The Razor's Edge
at like 20,000 i would hope so
Old July 10th, 2008, 12:35 AM   #6
1992 Lx
11.39@119.24
junk yard 351 200 bucks
stoker kit 1400ish
machine work 1000ish
Old July 10th, 2008, 12:46 AM   #7
1989 Mustang Gt
if your gonna go with a chevy motor at least go to Reher-Morrison and get a B/A big block
I love pink
Old July 10th, 2008, 01:00 AM   #8
The Razor's Edge
i like the new push rods...
Old July 10th, 2008, 09:18 AM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
87-89 Notchback - LS7 (505hp 427 ZO6 engine), T56. Life would be good.
Or
87-89 Notchback - 5.4 GT500 engine, T56
Old July 10th, 2008, 09:48 AM   #10
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
351W + twin 60mm turbo = ....... LS-this
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old July 10th, 2008, 09:49 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
LS1 + twin 60mm turbos = 351 seeing tail lights
Old July 10th, 2008, 10:13 AM   #12
Fast
Why ?
cube for cube a 351W will make same power as LS1, if its done right.
I'm expecting 700ish rwhp at 16psi, LS1 would make similar numbers
They are not the end all be all of engines.
Yes, great engine ..... Yes, you can make same power cheaper with a 351W
to a limit of course. past 700rwhp all bets are off, but you're
getting away from cars and into rocket ships at those power levels
God Help Us
Old July 10th, 2008, 11:51 AM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by r.barn View Post
Why ?
Stock for stock no production Ford engine is even close. The stock LS heads go along way. A friend of mine has a Camaro with a stock aluminum LS block, stock LS heads that makes 680hp naturally aspirated on pump gas and its his daily driver. At full weight with full factory interior it runs 10.0s. Of course it is a 408 so that helps and it has a spyder intake and a custom cam but those are all things you would do to a 351W as well. I have a small block Ford in my garage right now that makes just a bit more horsepower than that and I have a lot more money into it than my friend has in his LS. I don't agree that a 351W is cheaper. In fact I know it isn't. The LS series offers a great base to start with. The LS heads flow big numbers from the factory. Ford never has had a small block head that had anything but pathetic flow numbers from the factory. Don't let your love for Ford cloud your thinking. GM did a hell of a job with the LS series engines. Its probably one of the best if not the best small block produced as far as cost, power, economy and reliability are concerned.
Old July 10th, 2008, 12:02 PM   #14
Fast
I didnt say stock for stock ......... I said cube for cube.
the rest is arguable with valid points on both sides.
Again I agree, LS series are GREAT engines .........
and I thought that the LS series engines were designed by Mitsubishi, not GM
could be wrong.
to each his own, I just like my Ford small blocks
nothing against Chevy, got a Tahoe I love as my DD.
God Help Us
Old July 10th, 2008, 01:30 PM   #15
qwkvert's Avatar
1989 lx convertible
10.87 @ 128 ( old 302 combo)
qwkvert is on a distinguished road
notch
BBf stroker + twin turbo
t-56
FTMFW!!!
A bigger motor with a lot of parts they said would make me go faster......
Old July 10th, 2008, 04:39 PM   #16
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
built351w is on a distinguished road
ford 427 SOHC with an 8-71 blower on a 84 mustang with a really beefed up c-4
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old July 10th, 2008, 04:40 PM   #17
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
im just bored
motors
351w
trans
t56
body
87-93 hatch
lugs/brakes
disk all around
suspension
front k member
exhaust
x pipe
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old July 10th, 2008, 04:44 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'll take that a step further.
427 SOHC top fuel engine with a 14-71 blower and a lenco = death
Old July 10th, 2008, 04:47 PM   #19
87 Mustang GT T-top
The Novice is on a distinguished road
that would be crazy, but sweet!
Old July 10th, 2008, 05:35 PM   #20
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
Just Don't Put Aero Noses On Square Light Cars !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Threads Similar to: mustang.....aghhh
MOFO Production-Turbo 5.4 Stang-600HP Mustang GT-408w mustang-Ported Blower Cobra!! mofobucs Multimedia 24 August 20th, 2008 01:19 PM
Memphis Street Racing 4-13-08 LT1 Z28 Turbo Mustang LS2 GTO WRX STI Audi TT Mustang Mellon Videos 4 April 17th, 2008 08:54 PM
Pirelli P6 Four Seasons fit on 17x8 mustang rims? 97 mustang DiegoAlcala V6 Mustangs 7 April 20th, 2007 09:04 PM
So Md Mustang Club 3rd Annual Mustang & Ford Show Hwyman Mid-Atlantic 0 August 8th, 2006 03:39 PM
