Need Help With Rotors....
Old July 10th, 2008, 11:48 AM   #1
88stangGT is on a distinguished road
sorry guys never done these be4.... im replacing the rotors, and wheel bearings.. now is there two wheel bearing for one rotor theres one you see on front of spindle where cotter pin is.. then theres a bigger one in the rear sitting closet to dust shield.. im replacing both of em... now on the new rotors there no ring of metal that the bearing rides on.. i have the new ones... do i just install some grease and bang them in with a hammer or is there some way im supposed to do them????? please let me kno.. trying to replace everything in the front end at once so i dun have to do it again.. thnx guys appreciate all the help..
Old July 10th, 2008, 11:54 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is weird. I've never seen a set of rotors that didn't have the races already installed. You can drive them in with a hammer and a race driver but it would save alot of time if you went to a different parts store and bought rotors with races already installed.
Old July 10th, 2008, 12:08 PM   #3
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
You will probably need to have the outer bearing rings pressed
into the rotor. Thats a really tight fit there, doubt a hammer will work
without scoring the metal.
Any decent gas station garage should have a small press, take about 5mins.
and charge very little.
+1, odd the rotors didnt already have them in there.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old July 10th, 2008, 12:48 PM   #4
yea i kno its wierd.. i went to two parts store and both of them where like that... i tried just placing them in with a rubber hammer.. and can only get them in so far...
Old July 10th, 2008, 06:37 PM   #5
1989 ford mustang lx 5.0
lets find out?
89lxroadburner is on a distinguished road
well that SUCKS..that would piss me off. Thankfully never had that problem. If need be .. n the future i will surely check!
Threads Similar to: Need Help With Rotors....
rotors and such joejoe8455 99-04 7 April 10th, 2008 08:13 AM
Rotors... soccerboy08 V6 Mustangs 17 January 28th, 2008 02:32 PM
new rotors.... 01silversnake 99-04 15 October 9th, 2007 04:18 PM
Changing Rotors rjjones43 2005 - 2010 1 May 25th, 2007 12:35 PM
rotors droppedbass87 96-98 5 December 18th, 2006 08:33 AM
