LinkBack (1) | Thread Tools |
#1
87 Mustang GT T-top
Hood scoops for fox Stangs?
Hey guys i was looking to get a cowl hood but i have to cut back on some money for a new prob. with my car. But my question is can i buy a cowl scoop designed to fit a fox mustang perfectly and not look like crap? Or has anyone done this before that could help me out? Like i said i would like to get a new hood but a good on is like $500. My hood now had a dent in the middle so i was just thinking of doing this for now, until money comes. Something like this link below?
If ya guys can help me or know or any sites or anything that would be great, thanks guys! -The Novice. |
The Novice,
Hmmmmm. I had a fiberglass scoop like that on my old Nova, only mine was only 3 1/2". Problem was it was not fiberglassed on to the metal hood very well and eventually at triple digit speed it came loose, never to be attached to the car again. Basically, remember your going to have to pay to have the scoop molded to the hood. My opinion is that tall of a scoop is not going to go well with our body lines. Best of Luck. |
#3 | |
87 Mustang GT T-top
Yeah i was thinking about that, i was thinking about cutting the hole in the hood and then attaching it from the bottom and glue or id neede screw, prob need a little bondo or something to but i dunno just an idea.... But do they make any for stangs or anything? i just dont wanna buy one and have it be too long or somethin heh. What do you guys think though? |
98 Cobra
ive been thinking about the same thing, and yea my ideas were the same as yours, cut a hood in the top of the hood use some ummmmm i cant remember what its called but its like an adhesive but its mostly to help keep the plastic or fiberglass from warping and help with the weather proofing. then rivit it in, put some fiber glass resign over as bondo to "mold" it in. then use fiberglass to smooth it out. and with the hole cut in the stock hook it would be functional
95 Lightning-Twin Turbo
10.66@126
Put a 79 pace car/ 82 GT hood scoop on it and let'er eat. looks good and with a couple holes underneath the scoop is very functional. I'll try and get a couple pics posted of how it looked on mine before I got my cowl
'95 Lightning-842rwhp/936rwtrq pumpgas ![]() Twin T-70 Turbos 393w stroker(stock block) TFS CNC heads Cam Motion Custom Grind Hyd Roller cam BBRC EFI Spyder intake FAST Stock 185,000 trans(PI3000 converter,PUNISHER VB) Drag Radials always |
1983 mustang lx
my cowl was home made with some 18 gauge steel and hastily bondoed. i need to redo the bondo job. but i plug welded the cowl on, cut a hole under the cowl to fit the air cleaner, and gave it a quick bondo job.
![]() there she is |
1982 GT t-top
no proof of purchase
wow that looks crude ill give you an a for effort tho... but its better than the random scoop bolted on top of the stock fox body lines on the hood |
1983 mustang lx
yeah i was dumb and wanted to finish the hood too fast. im going to sand it down, smooth it up and try to make it look half decent. thats only untill i can afford a fiberglass hood, that hood i made probably weighs more than it should haha
1982 GT t-top
it wouldnt look half bad if the sides werent perfectly straight up and down, and you actually finished the bodywork I know how that goes tho
2002 Gt
Not Slow
![]() iTrader: 1 reviews
bondo would be a must for a paste on scoop like that..
The Razor's Edge
just wait and do it right..it will be worth it in the long run
1983 mustang lx
yeah i really didnt think that through when i helped my friend build that scoop at first (his car originally) he was in a rush to finish it and i havent had time to finish it because i want it to run first haha.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/79681-hood-scoops-fox-stangs.html
| Hood scoops for fox Stangs? | This thread | Refback | July 10th, 2008 11:57 PM | |
Threads Similar to: Hood scoops for fox Stangs?
| Hood Scoops on the 08 GT | N$SDarrell | 2005 - 2010 | 3 | March 6th, 2008 03:02 PM |
| Inally Side Scoops For 94-04 Stangs....but!!!! | mediaultra | V6 Mustangs | 7 | November 12th, 2007 01:25 AM |
| hood scoops | knightster420 | V6 Mustangs | 15 | August 21st, 2007 10:26 PM |
| ram air hoods and hood scoops, do they make much differance | villatic | V6 Mustangs | 9 | May 3rd, 2007 11:31 PM |
