1989 Mustang LX Tranny Problems Please Help
Old November 15th, 2006, 09:38 AM   #1
Steves LX is on a distinguished road
I have a 89 LX with a 302 bored 30 over and plenty of goodies. I have a Carbon Fiber BBK clutch, aluminum driveshaft, World Class tranny, BBK short throw shifter, and 4.11 gear. Long story short when I shift from 1st-2nd gear between 4000-6000 RPM youcan feel the 2nd gear engage with your hand on the shifter but when you dump the clutch it grinds and then engages into 2nd but if you are driving normal it engages into second gear w/out any problems at all. Its just when you get up into the higher RPM range. Can anyone out there help me out please?
Not that it matters but heres what I have in the motor:
302 bored .30 over
edelbrock plenum & intake
24LB Motorsport injectors
65CFM MAF & K&N Filter
75 BBK Throttle Body
Stage 3 Port & Polished Heads
303 cam/ low tension rings
Flat Top forged pistons/ High Volume oil pump
Mallory adjustable fuel guage
BBK full length headers
2 3/4" Flowmaster Exhaust/ Exit 3 1/2" tips
World Class T5 Tranny (which I am haveing problems with)
Aluminum drive shaft
4.11 lightened gears/28 spline axle
BBK short shifter/clutch relay
Underdrive pulley
Electric fan
Ran a 12.67 1/4 mile w/ stock tires
Motor dynoed at 325 H.P./375 LBS Torque
[/b]
Old November 15th, 2006, 10:14 AM   #2
rebuild time. sounds as if the syncros are shot
88 Mustang Coupe
www.rickscarcare.net
Old November 15th, 2006, 02:44 PM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
+1
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Threads Similar to: 1989 Mustang LX Tranny Problems Please Help
more tranny problems marks87gt 5.0 Mustangs 3 April 11th, 2007 11:07 PM
1989 Ford Mustang LX 5.0 nobletype 5.0 Mustangs 14 January 26th, 2007 07:30 PM
Tranny Problems... Frog's_Stang 5.0 Mustangs 2 October 25th, 2006 08:27 AM
