Discussing i'm ready for nitrous in the 5.0 Mustangs Forum. i have made up my mind about getting nitrous, and i have money in hand. ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2021 Mustang V12
Quad Turbo with nawz
Location: modified88dreamer likes penis in and around his mouth
i'm ready for nitrousthis is the kit i'm looking at. i'd like to start with a 75 shot, then work my way up to a 100 shot, then eventually a 150 shot. since this kit doesn't come with 150hp jets, what should i look for when i get ready to go with a bigger shot? would anything else engine wise need to be upgraded? spark plugs? timing? i want to go ahead and bite the bullet and buy all the safety shit too, like window switch, purge, bottle pressure gauge, and bottle heater. i know i'll probably need a fuel pump too, but what about injectors? what's the difference in -4 AN and -6 AN? how do i know whether i'm supposed to get a -4 AN purge valve kit or -6 AN purge valve kit? how does this window switch look for the setup i'll be running? or should i get the window switch that is already programmed for a 3,000RPM activation and 6,000 deactivation? i'll probably get one of these too and one of these. will it get too hot if i leave it on, or can i just turn it on ahead of time, and leave it on? i don't want to turn it on to warm the bottle, then turn it off when it gets to hot, and have to keep monitoring the temperature one of these to go with one of these ^what would i need to do to be able to mount those inside the car? it says i can mount them on the bottle or in front of the nitrous solenoid, but i want to be able to see the guages while i'm driving i know i'm probably forgetting some things, so add anything else i might need
slow car club - crew member 1 of 9 join www.moddedautos.com i had my bowl of WIN for breakfast. did you? |
88 Gt
not slow
injectors are not necessary
2021 Mustang V12
1990 LX hatch
At the 150 mark all you need is a fuel pump. With a wet kit, you'll never need bigger injectors.
#5 | |
2021 Mustang V12
any other advice? i know you know alot more about nitrous than i do
1986 lx notch
10.78 @ 124.96
for a 150 shot get a 255 pump , auto lite 24 sparkplugs , run premium gas and retard the timing according to the instructions
vids of my car the raggedy car you hear is the nova, he's running open headers and it's drowning out my car http://www.youtube.com/v/P3-7Oobydyo&hl=en http://www.youtube.com/v/rmPPnfHZ9WA&hl=en http://www.youtube.com/v/HcD354133Ac&hl=en |
#7 | |
2021 Mustang V12
can i run the stock spark plug gap? can you answer any of the other questions about accessories from my first post? and add anything if i'm forgetting something
Ignition? You'll be needing it for a 150 shot.
-6 an = 3/8" inside diameter -4 an = 1/2" inside diameter -4an is enough for 300 hp worth of nitrous...you do not need any -6AN nitrous line.
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
2021 Mustang V12
ok, now i'm looking at dual stage kits.. how exactly do they work? 75 shot in first gear, 100 shot in second, and 150 shot in third? this is the kit i'm looking at in particular:
Nitrous Oxide Systems (NOS) 05115-IINOS - NOS EFI Nitrous Oxide Systems - summitracing.com it includes a fuel pump too.. now this next question is a little confusing so bare with me.. is there any way that i could set it up so that it sprayed like a 100 shot in every gear, then later change it to 75 in first, 100 in second, and 150 in third if i wanted to, or will it always be a permanent dual stage setup? if i could do that, then that would keep me from having to buy 150 shot jets for the single stage kit i posted in my first post when i got tired of the 100 shot jets
2021 Mustang V12
when you say ignition, you mean everything? coil, distributor, and box?
#11 | |
1990 Mustang LX
9.36@143 mph
That is not a dual stage kit. The first kit you listed is a misprint. The 05115 is only 75hp and the 05115-ii is 75-150hp. Both kits use -4 line. The difference between the kits is jetting and the inline fuel pump. You will still need a bigger intank fuel pump and some good plug wires. Gap the plugs at .035. One heat range colder wouldn't hurt. No need for fancy ignitions or injectors unless your engine makes enough horsepower naturally aspirated to require bigger injectors. Bigger injectors won't hurt though but you will have to tune accordingly. The kit is designed around stock injectors. Bigger injectors require slightly different jetting with that kit. A window switch is helpful but not necessary. The blow down kit is required if the bottle is mounted inside the car. The bottle heater is nice but not necessary in a hatch back car unless you are racing on a cool night. I've had to put layers of blankets over my bottles in my hatchback cars to keep the bottle pressure down. The back window is like a magnifying glass when the sun is beating on it. If you do use a heater, do not leave the bottle heater on without monitoring bottle pressure or the burst disc will rupture and empty your bottle. The fuel pressure gauge you listed only goes to 15psi. You will need an EFI gauge that goes to 100psi. A pressure gauge on the bottle is a nice idea too. There is really no need to see it when you are driving. You won't be looking at it anyway. Pressure will change when the system turns on and when you purge. Just check your pressure before you pull up to the line and you'll be fine.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#12 | |
2021 Mustang V12
so let me just get this straight one more time - is the 05115-II kit dual stage or not? it does come with 75, 100, and 150hp jets, correct? also, are ford racing spark plug wires "good" wires?
2021 Mustang V12
and FYI - my car has an AOD, so i figured it might be a good idea to get a window switch
#14 | |
1990 Mustang LX
9.36@143 mph
Ford Racing wires suck. Go with MSD 8.5s or Accel 300+.
2021 Mustang V12
what do you think about a beginner to nitrous going with the 05115-II kit?
With a 150 shot, I blew the spark out at 3500 rpms with plugs gapped at 0.030" using the stock coil and MSD box. I would at least recommend a coil upgrade to get the most out of your nitrous kit. The stock coil is really at its limit at 300 hp flywheel and that is if it is in like new condition. The stock dizzy is good for 600+hp, you can always add a MSD box at any time.
1990 Mustang LX
9.36@143 mph
That is the kit I would get.
#18 | |
1990 Mustang LX
9.36@143 mph
2021 Mustang V12
i guess i'll be safe and spend the few extra dollars on a coil then. what are the difference in these two, and which one would be better suited for me?
MSD Ignition 8227 - MSD Blaster TFI Coils - summitracing.com and MSD Ignition 5527 - MSD Street Fire Coils - summitracing.com
Threads Similar to: i'm ready for nitrous
| I'm ready to do it | gooberhead320 | The Clubhouse | 69 | April 2nd, 2008 08:52 PM |
| All ready! | JASonic | The Clubhouse | 7 | March 23rd, 2008 01:20 AM |
| tell me are you ready? | nba1341 | The Clubhouse | 9 | February 25th, 2008 06:01 PM |
| whose ready for some ... | thetrooper31 | The Clubhouse | 30 | September 8th, 2007 11:14 PM |
| K&N CAI, Nitrous kit, nitrous accessories | Timber | Air/Fuel | 12 | June 28th, 2007 10:35 PM |
