F303 cam in a stock 302 any problems? - Forums at Modded Mustangs
post #1 of 30 Old July 12th, 2008, 10:08 PM Thread Starter
i was wondering if anyone has put a F303 cam in a stock 302 and had any problems?
cybertech is offline
post #2 of 30 Old July 12th, 2008, 10:27 PM
no its fine, but theres better cams out there and a cam alone doesnt do much, its not an ls1
93hatch is offline
post #3 of 30 Old July 12th, 2008, 10:48 PM Thread Starter
I want it for alittle improvement in power and I really want it for the rough idle. Plus i might be able to get it for almost nothing. Just alittle somethign to hold me over until I build my new engine
post #4 of 30 Old July 12th, 2008, 10:52 PM
ChuckTheKing
Sleeper_Stang_89's Avatar
if its cheap get it...
1989 Mustang GT - 331 ways to WASTE an LS1...
2013 Boss 302 #1561
Sleeper_Stang_89 is offline
post #5 of 30 Old July 13th, 2008, 03:38 AM
1slo5.0's Avatar
Yes it works fine but you will need to change your valve springs.
1slo5.0 is offline
post #6 of 30 Old July 29th, 2008, 01:44 PM
Send a message via AIM to Crob09
fgfd
i put one in my car. a stock 85 302. just changed my rocker arms.
Crob09 is offline
post #7 of 30 Old July 29th, 2008, 01:59 PM
1slo5.0's Avatar
Why did you change your rocker arms when you put a cam in? I'm not seeing the logic here.
1slo5.0 is offline
post #8 of 30 Old July 29th, 2008, 08:09 PM
ujslost's Avatar
Were 85s roller motors anyhow? Im thinking they started rollers in mid 85 but I cant remember? Im like Darrell though. Roller or not. Why would you change the rocker arms? And I still dont understand the reason for putting a larger cam in a stock motor? Like mentioned before. That works well for a chevy but the 5.0 cam is plenty more than what alot of ppl give it credit for.
ujslost is offline
post #9 of 30 Old July 29th, 2008, 09:05 PM
JBIGBOOTSY's Avatar
Yes it is a LS1!
JBIGBOOTSY is offline
post #10 of 30 Old July 29th, 2008, 09:12 PM
aint the f cam bigger than b and e? i heard you might have PTV clearance probs with the F and bigger
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8
GoodOleBoyzRacin is offline
post #11 of 30 Old July 31st, 2008, 09:29 PM
oldguywithan88's Avatar
I put a new E303 in my 2000-built FMS 302 short block, with rebuilt stock heads and have run it for 2 years with no problems - no noise and good power. I think the key is to not use springs with 140,000 miles on them. Why would you need to change the rockers, for a E303?
A show car: 5 year resto-mod compl. Jan, 2006. Big wins: Best Engine, 2007 FFW - Belle Rose, First Place, Modified - 2008 Biloxi Mustang Show, & Best of Show, 2008 FFW - Belle Rose. Not a total candy a$$. I like to get on it, too.
oldguywithan88 is offline
post #12 of 30 Old July 31st, 2008, 10:27 PM
Im putting an fcam on a stock headed forged 302 with a strim. IF it explodes Ill let you know.
flattusmaximus78 is offline
post #13 of 30 Old August 1st, 2008, 03:48 PM
1slo5.0's Avatar
Don't use stock springs on those stock heads or you will be sorry.
1slo5.0 is offline
post #14 of 30 Old August 1st, 2008, 03:59 PM
I've still got time to consider making the mistake. I do value your opinion tho darrel, I got to work a little more.
post #15 of 30 Old August 1st, 2008, 04:04 PM
1slo5.0's Avatar
Its not an opinion. When the spring you are using has less travel than the lift of the camshaft, things are going to break. You can either spend $80 now and put the correct springs in for the cam you are using or spend $800 or so later repairing all of the damage.
1slo5.0 is offline
post #16 of 30 Old August 1st, 2008, 04:10 PM
Any recommended spring kits or anything of that nature?
post #17 of 30 Old August 1st, 2008, 04:25 PM
1slo5.0's Avatar
Here is one example. If you shop around you can probably find something cheaper. Basically what you need is a diameter that is 1.400 to 1.47 with an installed height of 1.78-1.800 and spring pressure like what is listed for this spring.
Trick Flow Specialties TFS-51400413 - Trick Flow Valve Springs - summitracing.com
1slo5.0 is offline
post #18 of 30 Old August 1st, 2008, 04:26 PM
1slo5.0's Avatar
I'd recomend new valve locks too since you are in there but they are not necessary. Just a piece of mind.
1slo5.0 is offline
post #19 of 30 Old August 1st, 2008, 04:37 PM
Thank you sir. I need to buy a 255 and a crank pulley for my set up still. If I don't get these gt40p's I think I'll just invest the 65 bucks.
post #20 of 30 Old August 1st, 2008, 09:30 PM
JBIGBOOTSY's Avatar
You trick flow pimp you.
Human Verification
