I Need Help Asap!!
ok, i know you guys are the 5.0 experts so i need a few tips, I have a 65 mustang and just picked up a roller motor with some gt40p heads. My dad isnt the type to completly trick out a motor, So all i want to do is drop a cam in with the least possible mods i have to do. I want to go with the b303 cam and some trick flow valve springs because i like the choppy sound of that perticular cam. Will this be ok? or do i even need to change the springs?
please help
What Trick Flow valve springs? They make more than one set. I'd probably choose a different cam though. Any cam that is bigger than stock is going to have a choppy idle. The F303 or even the E303 would be a better choice.
iv been looking at the e303 too, im just not 100 percent sure on wich one? and the TFS-2500100 spring kit is what iv been looking at, im trying to keep it right around 300 bucks for now
Those springs will work.
so what cam do you think i should use for sure? the e or b?
If you are stuck on Ford Racing cams I'd go with the F303 with the heads you have. Comp Cams has some decent off the shelf cams too.
haha o god im so confused now.... give me a part number of a comp cam i should consider getting. And if it were you, what cam would you rather have?
steeda #18 would be a nice choice
maybe even a set of crane cams energizer 1.7 ratio pedestal mount roller rockers
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
Comp Cams XE270HR (part number 35-351-8) or maybe the F303.
hey man thanks alot!!! i think im going to go with the f303 or e303.
1986 lx notch
9.98 @ 135
i had an e cam and gt 40s heads, it ran really good ( mid 12s ) but it doesn't have much of a lope, the F cam definately sounds a whole lot better
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
your car sounds really good!!! id be happy if it sounded like that!!! so im def going with the ecam and some trick flow valve springs
1986 lx notch
9.98 @ 135
ohh sorry i wasn't talking about my current car, i was talking about a car i had a few years ago, my current car (the car in the vids ) has a 351 with a comp 292 hyd flat tappet cam
haha your crazy! , and 86 notch, i think ill still be happy with the e cam though. ill take pics here pretty soon
Threads Similar to: I Need Help Asap!!
| Need help ASAP | weems | The Clubhouse | 5 | May 9th, 2008 01:58 AM |
| help asap | silver_96 | 96-98 | 33 | March 5th, 2008 12:58 AM |
| help asap please | WeCircleTheProblem | V6 Mustangs | 14 | August 16th, 2007 07:21 PM |
| NEED HELP ASAP!! | 92stang0802 | 2.3 Mustangs | 53 | July 5th, 2007 01:03 PM |
| NEED HELP ASAP!! | VetteC5RFrEak | 5.0 Mustangs | 0 | August 3rd, 2006 03:01 AM |
