1990 foxbody
14.8@98mph
i have 2 questions
hey there guys it's been awhile since i have been on here because of a motorcycle accident but i am back here's what i need from you question#1
i am putting alot of parts on my 1990 hatchback 5.0 here they are trick flow aluminum heads 61 cc chambers 1.60-2.02 valves, 1.72 aluminum scorpion roller rockers, nos sniper nitrous kit {100 shot} mallory ignition system, 4:10 gears in the rear, rebuild the trac lock ,tubular rear control arms, subframe connectors,edelbrock performer rpm intake, and edelbrock carb {600cfm}now my questions are what cam should i go with {maybe an x-cam?}and {#2} what sort of times should i be looking at by the way the car has an aod tranny with a oregon 2500 stall converter in it. and the tires are 265-50-15 drag radials
your always faster then the guy in the mirror |
1990 LX hatch
The cam is a toss up. an x cam is a decent choice, I think trickflow makes springs that are perfect for that cam too, good to .542. I'm guessing that high 12's would be a good time for the mods.
'88 LX body '91 GT D/T
8.7 in the 1/8th
Heheh... In the July issues of 5.0 Mustang&SuperFords, there's a whole big article dedicated to camshaft selection.
The FRPP B & E cams are good choices. The "E" will require checking for adequate clearanced while the "B" is a drop-in affair. I have a B in my 306 and its awesome. Lopey, choppy idle, but not so much that is rocks my teetj loose and good power all the way to 6500 or so. And its got killer toreque from the get-go. I'm not sure how well it works with spray, but in N/A form, its sweet.
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
1990 foxbody
14.8@98mph
i must admit that i was hopeing for a little bit better out com with the issue on the cam i have heard through the grape vine that the x-cam would not work with the 1.72 roller rockers! but i am not sure so please whatever you guys know please tell me so that i do not order the wrong cam.....i need your help on this one guys
X-Cam with 1.7 you are cutting it close, have to check your clearance.
I do agree "B" cam has always been a solid choice and made us good power, but so has the "E" Both do have different manners,a simple fix could be that you are running TFS heads with their spring package I am assuming, so run a TFS cam set up for your combo they have several options to fit your build up and would fit right in with that combo, check them out on line they make it real easy to decide. Get it ,degree it and beat it like you stole it, good luck and I am sure it will run well, keep us posted.
![]() 93 G.T. 630-RWHP 608-RWTQ Pro-Charger D-1 347 Stroker Motor All Forged.TFS Heads Stage 3 Port Work.Cobra Intake Extrude-Honed. Custom Grind Comp-Cam. Custom PPG Paint Graphics. Built By: Bill Mongillo Motors Mongillomotors.com |
1990 foxbody
14.8@98mph
well thats more like it i do appriciate the input i will keep you posted
1990 foxbody
14.8@98mph
i have to admit that i love the wickedly sick lope sitting at the light in traffic but at the same time i want the power.so let me know what that would be ....by the way i have a buddy that said that he would trade me 8 of his 1.62 roller rockers for 8 of my 1.72 rockers and he said then i should be able to run the x-cam with no problems...is this true? i just feel
with all this cam stuff
#8 | |
8.7 in the 1/8th
I could tell you to go get the biggest, sickest cam on the market, but its not gonna be worth a shit on the street cause its profile is made for balls out 7K RPM power, you'd be pissed at that. If I tell you to get one thats made for everyday use, you'd be mad cause its doesn't shake the floorpan loose. Its not our place to tell you what to get. You know what you like more than any of us, but you have to be realistic in its application. If your car is more DD that track hero, get a more mild cam. If you get it to and from the track on a trailer, get a morew aggressive profiled design. Ford Engine Technical Specs & Information
1990 foxbody
14.8@98mph
well i am just looking for opinion i would like something that gives me a bit of everything power, sound, thats what these forums are for is dumbasses like me to find out what to put on his car so i just look for input from people
8.7 in the 1/8th
Nobody's sayin' you're a dumbass. Least of all me.
I've seen too many times somebody wants something, but its totally wrong for the application. Here (MM) and in person. I worked at a parts store for over 4 years. Saw plenty of shit that was WAY off, but they wanted it anyway. A week later, they were back in bitchin' and complainin' about something. Thats why I said that bit about 5.0 &SF magazine. Its a good artilce and has lots of info on numerous cams. And, it gives a few websites with cam selection guidlines. My personal opinion; get a "B" cam or an equivolent. Its a good N/A and N2O cam and it offers a lopey idle and awesome power. I just don't want you to put all your faith in somebody else's opinion. Do some solid research and make an informed decision.If you're having trouble, feel free to PM me and I'll do what I can to help ya.
1990 foxbody
14.8@98mph
o.k thank you i just want to get the best that i can and only want to have to do it once
1992 Lx
11.39@119.24
trickflow stage 1, my car has a sexy ass idle and doesnt feel like ive lost much low end
I have the b-cam love it. And it works well with the n20. If you run those 1.7 rockers with an x-cam more than likely you'll have to fly cut the pistons cuz 1.7 rockers give you a 30,000 more lift. But if you are going with trickflow heads look at there cams there decent cams for the doe. Good luck with the cam pick man!
to many parts and money to be so slow
1990 LX hatch
I have used a x cam with gt40p's that were milled .030. with no ptv issues
What rocker arm was you using?
1990 LX hatch
Frpp 1.6 pedestal.
1990 foxbody
14.8@98mph
well i have done some shopping around and i have decided to go with the ford racing
f-cam. so i hope that it works good i got the cam and the ford racing lifters for $200
1990 foxbody
14.8@98mph
hey there guys well i just wanted to let you guys know that i just orderd my head gaskets and my intake gasket set and my mallory coil to go with the mallory hifire 6 igniton this weekend i hope to be able to order my fuel tank sump and complete fuel kit{lines pump, filter and regulator,and all the fittings} so just thought i would let you know whats going on with the progress.........5.0guy
Threads Similar to: i have 2 questions
| Two Questions!! | andres0286 | Visual | 1 | April 19th, 2008 06:02 PM |
| 2 questions | oh2swapped | 99-04 | 3 | April 18th, 2008 03:25 PM |
| Questions About T-5 | fastford3388 | 5.0 Mustangs | 5 | November 27th, 2007 03:16 PM |
| 5.0 HP Questions ! | Smoph | 5.0 Mustangs | 4 | April 15th, 2007 01:40 PM |
| 2 Questions | mikethetigerrr | V6 Mustangs | 21 | October 25th, 2006 09:23 AM |
