C4 swap??
Hello, I am planning on swapping a c4 into my 90' Lx in place of the stock AOD. Will the AOD crossmember work? Any other modifications needed?
The Razor's Edge
why not build up the aod? do you already have a c4
I don't have one yet. I have heard the aod is weaker, is this true? what parts in a aod need upgraded?
The Razor's Edge
you can build up aod's to be pretty stout...not as strong as c4's or the boat anchor c6's
Are the manual transmissions in the four cylinder models the same as the V8's ? I found a great deal on a whole 4 cylinder car.
You can make a stout AOD with the right parts. There are alot of people putting alot of horsepower thru AODs. If you drive the car on the highway alot I would stick with the AOD. Drive your AOD around in Drive and not Overdrive for a couple weeks and see how you like your fuel economy and the extra noise. That will be something to consider when switching to a C4.
They are different. Different gear ratios and the 4 cylinder trans is much weaker.
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
If you need a bellhousing, I have a C4/SBF SFI approved bellhousing I need to get rid of.......
Threads Similar to: C4 swap??
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 08:00 AM |
| 5.4 swap | Darkside_03_GT | 99-04 | 12 | October 5th, 2007 07:41 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
