Disappearing coolant. - Page 2
LinkBack (1) Thread Tools
Old July 21st, 2008, 08:58 PM   1 links from elsewhere to this Post. Click to view. #21
90 Mustang GT Convertible
INSTALLER020 is on a distinguished road
Send a message via AIM to INSTALLER020
Filled the Radiator and not the overflow.
I filled the radiator and not the overflow. Still losing coolant at the same rate. Will swapping the Thermostat do me any good?
Matt
Old July 21st, 2008, 09:10 PM   #22
94cobraStang's Avatar
94
11.47@120.58
94cobraStang is on a distinguished road
4sure it will dude
Old July 22nd, 2008, 08:36 AM   #23
Good to know.
Originally Posted by 94cobraStang View Post
4sure it will dude
I already bought the thermostat and will get it swapped this week.
Matt
Old July 22nd, 2008, 02:18 PM   #24
RevPerformance's Avatar
1995 SVT Cobra
13.01@103.4
RevPerformance is on a distinguished road
Send a message via AIM to RevPerformance
I have to agree sounds like a blown headgasket to me... although it is possible that it may be a bad cap which would cause all the pressure to bleed off into the overflow tank essentially steaming the coolant away. Simple fix check that first. Good Luck!
Why Turbo? You'll find out on the big end!
Old July 22nd, 2008, 11:22 PM   #25
92stang's Avatar
1992 MUSTANG LX
92stang is on a distinguished road
my car was doing the same thing recently there was not any obvious sign of it leaking but it kept getting low i changed the water pump and it solved the problem i still dont know what was really the issue
3inch cowl hood with svo scoop for sale, north alabama area
Old July 23rd, 2008, 11:24 AM   #26
Reply.
I replaced the cap with a new one.
After the thermostat I will do a compression test, if that isn't it i will check the water pump.
Thanks,
Matt
Old July 23rd, 2008, 11:54 AM   #27
tmoss's Avatar
tmoss is on a distinguished road
If the pump shaft seal or housing were leaking, I'd think you could find evidence of that.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old July 23rd, 2008, 04:33 PM   #28
ryans88gt's Avatar
It is a blown head gasket... ... ... ... ... ... ... ... zzz
Old July 25th, 2008, 11:27 AM   #29
I know....I know!!! Time for some heads!!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/80423-disappearing-coolant.html
Disappearing coolant. - Page 2 This thread Refback July 23rd, 2008 04:43 PM
Threads Similar to: Disappearing coolant.
Coolant whtpny 99-04 6 June 10th, 2008 06:10 PM
coolant tube! mr. mopar 96-98 9 October 19th, 2007 01:21 PM
coolant adam0421 2005 - 2010 4 July 9th, 2007 11:02 PM
Coolant level? TorqueMonster V6 Mustangs 1 August 23rd, 2006 11:36 PM
