LinkBack (1) | Thread Tools |
Disappearing coolant.
I have 1990 Mustang GT. Over the last couple weeks I have been losing radiator fluid and it has been getting incresingly worse. I have a friend who is a mechanic. We pressure tested it with no leaks. There is no fluid in the oil or transmission fluid. I have replaced the radiator cap. I have noticed a couple times the fluid is bubbling out of the overflow all over the place.
My buddy says he can only think of 2 things. 1. Thermostat 2. Cracked head. Please help me. Matt |
89 Mustang LX
7.90@90mph 8th
![]() iTrader: 1 reviews
makes sure that the water pump isn't locked up or hard to turn. IF your not seening any white smoke i would really doubt it's a cracked head or blown head gasket. Unless you got it really hot. do a compression test on the cylinders and that will tell ya if you have a bad gasket or head. has anyone replaced the thermostat recently. my buddy had the same problem with getting hot and it was because he put the thermostat in the wrong direction.
#3 | |
Reply.
I alos forgot to mention it never overhets or get's much above 180 degrees. I am thinking about swapping the Thermostat out for a new one to see what happens. Keep the info coming, it is greatly appreciated. Matt |
90&94 GTs; 79&91 Broncos
Just for S&Gs leave the tank empty, radiator full, and unplug the sensor. Mine had a crack in the bottom of the tank and would lose coolant---never enough at one time to leave its' mark though. It drove me up the wall until I decided to say the hell with it and unplug the sensor and make sure the radiator was full myself. What do you know, the radiator stayed full!!!
I never lost as much coolant as you at one shot, but it's worth a try if you can't find a leak anywhere else. |
1990 foxbody
14.8@98mph
do you have any wetness on the passanger floorboard?could it maybe be a heater core?
your always faster then the guy in the mirror |
P-351: I will try this.
5.0 guy: this is the first thing my budy recommended, no wetness. AAARRRGGGHHH!!!! Frustration, LOL!!!!! |
1987 mustang lx 5.0
i had a similar problem with my car, my problem was that there was a hairline crack on the lower hose opening on my radiator. i couldn't understand why it was losing fluid and i pressure checked it and it was fine. i got under the car one day and grabbed the bottom of the core support and felt something wet and then i knew it was anti-freeze. all i did was get a bottle of BARS Pelletized Radiator Sealent and poured it in the radiator, drove around the block for about 10 minutes and the leak was gone. don't know if you're problem is the same but it doesn't hurt to check the bottom of the core support for anything wet
1993 5.ohhhh
12.97 @140mph
my car eats the stuff up to.... but theirs no fluids on the driveway, and I'm yet to dive under the car.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1991 Mustang GT Cobra
I thought headercore aswell, does your windows fog up at all with the heater on?
1991 Mustang GT Cobra Paxton Supercharged |
Reply.
I will check under the car this weekend.
We are going to swap the thermostat just to be sure, then we will check compression, but i am convinced it has to be somewhere else. The amount of fluid i am losing in the short amount of time is telling me it would have to be a pretty large leak. The only tiume i ever found any radiator fluid on the ground was when it came out of the overflow container. LOL, fun, fun, fun. |
Have you tried leaving the tank empty and seeing if the radiator stays full yet????
I will try that tonight. |
blown head gasket or cracked head...end of story...
been down that road a time of two...bubbling out of the overflow is almost always the head gasket. You're in luck though, it is pretty easy to fix if you have about $50 and a weekend of free time.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#14 | |
Thanks.How much horse power can a stock auto traqnsmission handle? Matt |
stock transmission can handle between 200 and 600 hp. Depends on a lot of variables, the biggest of which is how you drive it and what kind of tires and clutch you have.
Aggressive powershifting, sticky tires, and grabby clutches are the hardest things on T5s.
#16 | |
Thanks man.So if I am planning on maxing out at around 350 RHP, I should be fine with the stock auto tranny. Thanks, Matt |
1994 GT
its not so much hp the destroys tranny's..its the amount of torque the motor produces, and size of tires
Cohagan Engineering, Inc. |
Thanks fpr the input.
thanks everyone!!
do the cylindr pressure test. if that is not it, don't forget that water can leak out of the EGR spacer and enter the engine where it will not show up on the ground.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
^^^that's true, but overflowing coolant bottle means cylinder pressure is pushing coolant out. A leaking EGR spacer will not push coolant out of the radiator.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/80423-disappearing-coolant.html
| Disappearing coolant. - Page 2 | This thread | Refback | July 23rd, 2008 04:43 PM | |
Threads Similar to: Disappearing coolant.
| Coolant | whtpny | 99-04 | 6 | June 10th, 2008 06:10 PM |
| coolant tube! | mr. mopar | 96-98 | 9 | October 19th, 2007 01:21 PM |
| coolant | adam0421 | 2005 - 2010 | 4 | July 9th, 2007 11:02 PM |
| Coolant level? | TorqueMonster | V6 Mustangs | 1 | August 23rd, 2006 11:36 PM |
