1993 5.ohhhh
12.97 @140mph
What maf to get
So I'm swapping over to another 302 in the upcomming weeks. this one has 30lb injectors. I have a c&l cold air intake calibrated for the stock injectors. I have a v2 strim, but She's going on later. So I wanted to purchase a maf calibrated for the injectors so I can ride around all motor for a while.
the thing is idk what size to get. Late model restoration sells like a 73mm 75 and 76mm maf calibrated for the injectors but idk what size fits. For referance I took some pics ![]()
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1992 Lx
11.39@119.24
i just installed my Pro-M 75mm for the 24lb injectors, i love it, made my car run sooo much better
1993 5.ohhhh
12.97 @140mph
I know I need the maf, but Idk the size?
1993 5.ohhhh
12.97 @140mph
Also for my blower I have this power pipe I need am af for, but I have no lcue what size maf fits the bill cause the pipes so big.
If you already have a C&L meter on there all you need to do is buy a calibration tube for the 30lb. injectors, they are like $20 and you'll be able to keep the meter that you have now
98 Cobra
if you have a stock MAF in there then just go with a 75mm calibrated for your injectors, the 75mm 73mm etc is the inside of the pipe not the outside size. heres a pic for reference, i went from stock to 75mm
http://i280.photobucket.com/albums/k...bra50/maf2.jpg http://i280.photobucket.com/albums/k...bra50/maf1.jpg http://i280.photobucket.com/albums/k...bra50/maf5.jpg |
1993 5.ohhhh
12.97 @140mph
Thank you thats all Iwanted to know... other then that I need to figure out how to run a maf on this power pipe.
1993 5.ohhhh
12.97 @140mph
Vortech 8A001-023 - Vortech Recalibration Sample Tubes - summitracing.com these will work for my c and l?
98 Cobra
just buy the rubber sleeves that fit both ends, they carry them at like pep boys
what size pipes do you have? |
98 Cobra
i dont get what that sample tube is for? is it a cheap way to try and recalibrate your maf for diff injectors?? as long as you buy a maf thats been calibrated to your injectors then you dont need anything like that
What is that power pipe from? It doesn't look like one for a fox Mustang with a Vortech. It kind of does except for the big thing welded on the side unless that was added later for a larger bypass.
With a power pipe, you will need the rubber boot that connects the pipe to the SC (big curved hard rubber 90degree elbow about 4in diameter) and one to connect to a fender mounted MAF sensor which would vary depending on what MAF you have. I don't think any C&L MAF's are fender mount but with a recal kit, you can make it work now. An Example of an Anderson PP http://www.andersonfordmotorsport.co...s/AF-0101C.jpg
1993 5.ohhhh
12.97 @140mph
The welded hole is just for the bypass hose to reconnect at the intake. The pipe is about 3.5 inches, and I can't say that I've measured it. I know I could get a rubber coupling, but I wouldn't even know were to find one that goes big to small to fit the right maf. And IF I do what maf to buy?
I'm convinced I'm ganna go n/a for a while tull I put together some other odds and ends for the vortech kit and what not.
Yes, cheap way. All you are doing is fooling the mass air meter which then fools the computer.
1993 5.ohhhh
12.97 @140mph
ok I'm ready to buy. were can I get some sample tubes for my maf for 30 pounders?
1993 5.ohhhh
12.97 @140mph
once again I found these.... do I need to buy two? Quantity said sold individualy.
1993 5.ohhhh
12.97 @140mph
top
90 mustang notchback
if you end up buying a new mass airflow i have a sct one on my car it has a 4in od you would have to get it tuned but you wouldnt max it out its good for 1000hp so if you end up running more boost later you wouldn't peg out your airmeter it has a new style connector so you would have to either buy adaptor off of sct or get one of a new mustang like 99 up or you can get one from ford
306 Turbo Notch D&G Tuned ![]() 1999 Chevy Silverado 5.3 |
1993 5.ohhhh
12.97 @140mph
Thats good but right now I'm ganna run na for a while. I want to keep the maf on my c&l but I want to recalibrate it for 30 pound injectors. I wanted to know if these sample tubes would work
Vortech 8A001-023 - Vortech Recalibration Sample Tubes - summitracing.com and do they come infividual or in a pair.
1993 5.ohhhh
12.97 @140mph
top
#20 | |
Threads Similar to: What maf to get
| Maf ? | 5 pt slow | 5.0 Mustangs | 24 | March 8th, 2008 01:04 AM |
| TB and MAF | Till | 5.0 Mustangs | 4 | February 23rd, 2008 08:33 PM |
| MAF | Mach Boy | 4V / SVT | 7 | February 19th, 2008 07:04 PM |
| MAF | AnglicoGT98 | General Tech | 3 | September 17th, 2007 09:26 PM |
| 24#'s and . ..MAF? | mikebert | 5.0 Mustangs | 35 | August 3rd, 2007 05:41 PM |
