In your opinion
Old July 17th, 2008, 02:02 PM   #1
87 GT
14.2@98.something
darkhorse50 is on a distinguished road
In your opinion
I'm about to make my next parts purchase, and I have been contemplating what to get. First of all I'm buying a shifter and underdrive pulleys, thats fo show. But after that its a toss up, Im either gona buy the march ram air system/kenny bell system, or instead an a/c delete and smog delete. Just would like to know your opinion maybe you can make my decesion easier
Old July 17th, 2008, 02:10 PM   #2
Casper98GT's Avatar
Unsure of exactly what your mods are. I would deff. get a shifter, not sure of youre exact choice...but i would lean twords a Steeda Tri-ax. I have used Hurst and Pro-5.0 and i like the Steeda better.
Wouldnt waste my money on underdrive pulleys. Maybe people will disagree, but thats ok. Wouldnt put money into that March Ram-air system or an a/c-smog delete. Youre really loosing no power from having smog and ac. Plus it cools you down. I would just get a JLT CAI like 100.00 from americanmuscle.com. Works good and will support youre later MAF/TB sizes.
Just one persons thoughts. Im sure you will get more.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old July 17th, 2008, 02:10 PM   #3
ujslost's Avatar
For the price of the march ram air kit. I think its useless. As far as a/c and smog delete, you dont "have" to buy anything. Just remove them and buy a shorter belt. FREE MOD!
Save that money for some "real" mods like exhaust , or gears, if you dont already have that. Get a JLT CAI. I hear they are the best for the money.
Old July 17th, 2008, 02:12 PM   #4
ujslost's Avatar
I agree on the underdrive pullies also. They are cheap sure. But dont make much differance at all and if you deceide to go SC later you will have to remove them anyhow.
Old July 17th, 2008, 02:44 PM   #5
1992 Lx
11.39@119.24
i noticed a difference with my ud pulleys, theyre aluminum though apparently the steel ones arent noticable cuz the weight difference is so sllight
Old July 17th, 2008, 02:53 PM   #6
91cobra5.0's Avatar
94 GT
if you do go with underdrives then you should upgrade your alternator
94 GT - Deep Forest Green
Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block
Old July 17th, 2008, 02:57 PM   #7
1992 Lx
11.39@119.24
i didnt upgrade mine, but my radio doesnt work and i didnt do the alternater pulley so i guess it dnt matter in my case, but i can see my headlights dim at idle
Old July 17th, 2008, 03:07 PM   #8
87 GT
14.2@98.something
Oh sorry didnt state my mods, I have equal length headers, cattles H-pipe and flowmaster catback, 3.73 gears and aluminum drive shaft. I looked into a JLT cold air kit, but they dont have one for speed density. Im either gona buy a tri-ax shifter or an MGW. No body thinks getting rid of your a/c and smog pump are worth anything huh?
Old July 17th, 2008, 03:26 PM   #9
Casper98GT's Avatar
Mod list looks good, i would maybe save some money and look into a H/C/I kit, or put them together a little at a time and do it all at once. Or look into a cheap Vortech system. You can find them on mustang forums 4 sale all the time around 1500. If not i would do some suspension work.
Also if you do plan a 3G alternator in the near future, use this it makes thing easier. Very easy install and now my car actually charges. haha. If not a one-wire from summit works just as well.
Also if you do plan on removing a/c and smog here is a nice little pic as well.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old July 17th, 2008, 04:19 PM   #10
87 GT
14.2@98.something
Casper98, thank you for that info on the short belt, I notice that it dosent bypass the a/c compressor though? I see that you dont run your a/c or smog pump, I take it you probably used this short belt setup, what did you do to eliminate the a/c? In regards to saving up for the H/C/I setup, I forgot to mention I have a set of gt40 heads and a tubular gt40 intake that are going on this winter with a steeda 19 cam.
Old July 17th, 2008, 04:39 PM   #11
Hunt_chevs's Avatar
2002 Gt
Not Slow
i really liked my tri-ax
Old July 17th, 2008, 07:30 PM   #12
ujslost's Avatar
I am using a 1 wire alt from summit. I have no problems with it. I am using march underdrive pullies. Running a mark viii electric fan. A 400watt amp and 1 12 inch sub. No problems so far with the summit 1 wire alternator. I believe its rated at 100 amp btw.
Also I am running the short belt on my car with no AC or Smog. You asked about the diagram not showing the AC deleted. Look at the pic again and imagine the AC not there and just get a belt to fit. Or I can get you a pic of my belt setup with the pullies and alt listed in the first paragraph.
Maybe you should take your money you have there and upgrade to MAF? Or save up a little more and get a nitrous kit to play with or a custom grind cam to match your heads and that intake you have already.
Old July 17th, 2008, 07:30 PM   #13
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
N I T R O U S ! ! !
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old July 17th, 2008, 11:18 PM   #14
Casper98GT's Avatar
Responce
It does include the a/c. Its the short belt one. I have no a/c or smog. I got a Ford racing a/c delete and it moves the Powersteering up to where the a/c was. You ask what size belt...well almost every car is different. Kinda like my car:
a/c delete, p/s moved up
1993 Cobra Waterpump pulley
Underdrive Crank pulley
3g alternator ( 1995 size pulley )
And im using a 68.5 inch belt.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old July 17th, 2008, 11:51 PM   #15
Bigfatts's Avatar
Badass Mother 3000
Twice as fast as your ass!
Bigfatts is on a distinguished road
One of my next mods would be a mass air conversion.
Old July 18th, 2008, 12:18 AM   #16
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
so the diagram is an underdrive diagram?
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Threads Similar to: In your opinion
i want ur opinion 01sta1k3r 99-04 4 January 27th, 2008 01:34 PM
Need ur opinion! wolfwood 2.3 Mustangs 13 April 18th, 2007 03:52 PM
Want your opinion! dblindberg 2005 - 2010 41 February 6th, 2007 01:01 AM
your opinion schmitty The Clubhouse 15 January 20th, 2006 07:56 PM
