1991 Mustang GT Cobra
Starter problem
Hi every1, everytime i drive for a long period of time turn the car off 75% of the time it wont start. It will click but not turn over but if it sit for about 10mins with the hood up no problem. Any ideas? THX
1991 Mustang GT Cobra Paxton Supercharged |
When you hear the click, do your headlights dim and does it sound like the starter might be trying to turn? If so, I would say the starter is failing.
When they get old, the windings start to go bad and they can require more power and provide less torque, when they are hot, it is much worse. A weak battery has a harder time turning over a bad starter so it could actually be a combination of both. Clean your terminals and have your battery checked for free at AutoZone/Advance Auto or what ever you have up North. If that checks out good, get a starter. If it is bad, get a battery and if it is still harder to start when hot, go back and get a starter.
89 Mustang LX
7.90@90mph 8th
![]() iTrader: 1 reviews
are you running long tube headers? I have had this problem before. I used header wrap and a starter heat blanket and is seems to have fixed it.
2002 Gt
Not Slow
clean your battery terminals,. if that doesnt work its a starter or alternator problem it sounds like
I had new alt and starter in the past year installed but I think the heat is a issue, Im running equal length headers and maybe causing the starter to get too hot. S
You can get a wrap style heat shield at just about any parts store. When you say you have equal length headers, do you mean shorties? No shorties should cause a heat issue unless your h-pipe is way out of whack.
new battery and starter cables will help. I have starter heat soak issues with long tubes. hitourque ministarters help too.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
long headers i guess i have bbks are great, I will try new starter cables and see what happens. THXall
Threads Similar to: Starter problem
| Starter solenoid clicks at the starter but wont start the car?? | 95StangSVT | 94-95 | 13 | March 11th, 2010 11:22 PM |
| BullDog Security Starter Problem | my_2000stang | V6 Mustangs | 1 | January 20th, 2008 04:30 PM |
| Starter/solenoid problem | WIKD | 2.3 Mustangs | 2 | October 4th, 2007 08:15 PM |
| starter problem | superbeef1000 | 99-04 | 1 | March 23rd, 2007 11:38 PM |
| Starter Question/ Problem (Heat Soak) | xjer88 | 5.0 Mustangs | 13 | March 7th, 2007 11:55 PM |
