Discussing Car is cutting out top end!! in the 5.0 Mustangs Forum. I have an 89 ford mustang with a procharger on it!! It runs good prretty ...
Old November 16th, 2006, 11:36 PM   #1
I have an 89 ford mustang with a procharger on it!! It runs good prretty much all the time but when i mash the gas to the floor at about 4500 the motor cuts out pretty much completely!!! Its also only full throttle. If i mash it about 3/4 itll sing to 6000 but as soon as i hit full throttle it cuts out!! Can you help me??
Old November 16th, 2006, 11:48 PM   #2
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Have you had it on a dyno to see what the fuel curve looks like? That is where I'd start.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old November 16th, 2006, 11:51 PM   #3
Re: Car is cutting out top end!!
what have you got your spark plugs gapped at? could be a coil or other ignition issue (TFI, cap/rotor, plug wires). could also be fuel related.
have you Checked for Codes?
89 GT t5 3.73
www.my5oh.com/
Old November 17th, 2006, 12:23 AM   #4
On Probation
Tony_90fox's Avatar
definately check the plugs, wires, cap and rotor.
MM Sapper Squad
Originally Posted by Regency 2007 View Post
MSO's stupidity has never stopped amazing me since the day he joined this forum.
Old November 17th, 2006, 12:42 AM   #5
i Know the fuel pressure is good but the only thing im curious about is when my fuel pressure raises for the supercharger the pressure jumps up and down for 40 to about 75! And yes i checked for codes but didnt get any!! I also have my plugs gapped at .035 thousandths! 2 steps colder
Old November 17th, 2006, 02:35 AM   #6
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Does the pressure jump up to 75 or does it fluctuate while you are wide open. If it just jumps to 75 at wide open throttle that is normal. If the pressure is fluctuating, you have a big problem.
Old November 18th, 2006, 09:05 PM   #7
stang fanatic's Avatar
Think of it this way....at 3/4 throttle, your fuel demand is 75% approx., and so your average fuel pressure between 40 and 75 is nominal since air pressure is lower. At full throttle, your supercharger is giving it s all, fuel demand is 100% and so your average fuel psi is now not adequate enough to support the demand and air being fed into the motor. Remeber, the air is still there, but sufficient fuel isnt, find out where the presure loss is from...pump, filter, collapsing line, etc.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old November 19th, 2006, 08:15 PM   #8
LOOSE THE FMU! Thay suck!
Could also be pinging, mine did that whe I first put on the S-trim. Back down the timing and see if that helps. What injectors you rinning? With 42's and a calibrated MAF you can loose the FMU.
Threads Similar to: Car is cutting out top end!!
Cutting Out Illuminator 5.0 Mustangs 2 November 13th, 2007 11:45 AM
car cutting out..please help 89LX347 5.0 Mustangs 12 June 4th, 2007 07:53 PM
car cutting off raceruler03 99-04 4 April 14th, 2007 12:40 PM
cutting my antenna? TheTechnical99 Electronics 10 January 3rd, 2007 12:04 AM
Car Is Cutting Out! Help! streetstang06 96-98 10 September 14th, 2006 09:17 PM
