LinkBack (2) | Thread Tools |
#21
95 opalfrost gt
Depends on what you want mechanical or electrical and where do you want to mount it?
Here is my Autometer electrical (right side)
#22 |
can i get either for under 100?? i dont care where it goes as long as it looks .. not rigged lol
#23 |
oh and i bought my car with a bunch of bolt ons and crap on it, How do i make sure my timing is not advanced?
#24 |
1986 lx notch
9.98 @ 135
it probably is, buy a timing light, i have a cheap actron light with the nob on it and it works plenty good enough for me
btw whenever you check or adjust the timing make sure you pull the spout connector out
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
#25 |
how much should i pull for a 125 shot? 5 degrees?
#26 |
and how much power would i lose from that off the bottle?
#27 |
95 opalfrost gt
I dont want to sound like a dick, but it seems as you have never used nitrous before so instead of hitting the 125 shot start with a 75 shot and work you way up. Pull your plugs after each nitrous blast.
#28 |
Oh absolutely no i am deffinitely starting at 75, i just dont want to grenade my engine. I have never used nitrous, good inference. 95 opal is that a picture of your car? its sweet man.
#29 | |
95 opalfrost gt
Tuning Linx - Nitrous Oxide Tuning Nitrous Forum - Powered by vBulletin
#30 |
1986 lx notch
9.98 @ 135
set your timing at 10 degrees and put the 125 shot in and you won't have any problems ( unless you fail to use premium gas )
#31 |
Yes at 95opal and 86 Notch say, Nitrous can be a very harmful if not preped correctly. Make sure you run a cooler plug, adjust the timing, run premium gas, put a little octane booster in as well. If all this is done correctly everything should run smooth. Make sure you keep in eye on your plugs, you will be able to tell if you need to adjustments just from looking at your plugs. Its an amazing poweradder but could end up very bad if not installed correctly or adjusting your engine for the nitrous. One last tip, Pick up a nice fire extinguisher just to be on the safe side. Nitrous is not flammable unless mixed with gas. Better safe then sorry. I found out the hard way a few times. Goodluck with the install. If you need some help ask some more questions.
PaT #06 |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/80783-installing-nitrous-tomorrow.html
| Installing nitrous tomorrow - Page 2 | This thread | Refback | July 20th, 2008 09:07 PM | |
| Installing nitrous tomorrow | This thread | Refback | July 18th, 2008 09:33 PM | |
Threads Similar to: Installing nitrous tomorrow
| installing this tomorrow,hope it fits | tom2000r | 99-04 | 16 | May 28th, 2008 02:22 PM |
| Installing tomorrow! and my gas mileage! | Top Gear | V6 Mustangs | 27 | September 30th, 2007 10:23 AM |
| Installing Edelbrock Direct Port Nitrous System on a Vic Jr. | 99mustang232 | General Tech | 0 | March 24th, 2006 11:00 PM |
