Installing nitrous tomorrow
LinkBack (2) Thread Tools
Old July 18th, 2008, 06:39 PM   1 links from elsewhere to this Post. Click to view. #1
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
Yay this is fun i got the fuel pump, the zex wet kit, the bottle pressure gauge, zex bottle warmer, and purge kit. The only thing is, i heard you have to keep the bottle at 900 psi, is it hard to do that? Do i have to constantly look back at the bottle and make sure its at 900psi? How will i know when to purge and what not?
The kit is pretty, shiny purple, all stainless braided lines, im excited for the 100 foot pound torque increase with just a 75 shot, and when i get the balls for the 125 shot it will be excellent.
Old July 18th, 2008, 06:45 PM   #2
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
You may want to invest in a bottle warmer to keep the pressure in check. If you dont want to constantly look back at the bottle mounted guage get an Autometer guage to mount up front on your dash or in a pod. You purge before you spray to clear the lines of air.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old July 18th, 2008, 06:48 PM   #3
1BADSTANG's Avatar
I have a bottle warmer and a purge kit, but will the bottle warmer overheat it? or does it know when to stop?
Old July 18th, 2008, 06:53 PM   #4
95opal's Avatar
95 opalfrost gt
What warmer do you have? A temperature controled unit or pressure controled unit? If temp controled unit then you will have to turn it off.
5.0 magazines
Old July 18th, 2008, 07:02 PM   #5
1BADSTANG's Avatar
Zex Nitrous Bottle Heater
so that means what do i just have it linked to the arming switch?
Old July 18th, 2008, 07:20 PM   #6
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
It's not a tough as you think. Leave the warmer on for 10 to 15 minutes and it'll be good to go. You really can't overheat it. More psi the better, but not much over 1000 KABOOM
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old July 18th, 2008, 09:12 PM   #7
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
small torch works faster then a bottle heater and won't drain your battery
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old July 18th, 2008, 09:16 PM   #8
Damaso is on a distinguished road
I could be wrong but don't they come with thermostats on the bottle warmers
1998 GT 5spd- Full pi swap, Fenderwell CAI,UPR Catted X-Pipe, Mac FlowPath Cat-Back
1988 LX auto- Pypes violator cat-back, UPR X-Pipe, Shift Kit, 4.10 Gears, Pulleys, Suspension upgraded, CAI
1999 GT 5spd- CAI, Pypes violator cat-back
Old July 18th, 2008, 10:06 PM   #9
1BADSTANG's Avatar
okay so i guess im good with that, Another thing is, i have a ttaylor battery reolcation in the rear hatch, and its as far back as you can go without interfering with the glass of the hatch, the gas tank was removed to install it. But what i mean is, where is it safe to drill for the nitrous? the adjacent of the right rear hatch? can i just put the bottle in the back left and not worry about hitting shit? let me know, thanks a lot!
Old July 18th, 2008, 10:23 PM   #10
86_Notch's Avatar
1986 lx notch
9.98 @ 135
its only 3 bolts to drop the tank, 2 for the straps and 1 little one that holds the filler neck, it's much easier in the long run then trying to get bolts up thru the floor with the tank inplace. OR you could do like i've done a few times in the past and mount it sideways between the drivers ( or passengers ) seat and back seat
Old July 18th, 2008, 10:46 PM   #11
1BADSTANG's Avatar
yeah but i already have the battery box there, it wouldn't even fit really there and look neat. I think i will take your advice and put it behind the passenger seat. thanks.
Old July 18th, 2008, 10:49 PM   #12
1BADSTANG's Avatar
where exactley do i tap the fuel from?
Old July 18th, 2008, 10:58 PM   #13
86_Notch's Avatar
1986 lx notch
9.98 @ 135
schrader valve, on the metal fuel lines on the passengers side, near the alternator
Old July 18th, 2008, 11:01 PM   #14
1BADSTANG's Avatar
Do i put a t fitting in their? or tap into it? thanks for your time btw
Old July 19th, 2008, 08:20 AM   #15
86_Notch's Avatar
1986 lx notch
9.98 @ 135
your nitrous kit should come with a fitting and instructions, basically you unscrew the schrader valve and thread the new one in, be careful NOT to overtighten it or it will break ( speaking from experience )
Old July 19th, 2008, 09:42 AM   #16
1BADSTANG's Avatar
should i use like a teflon paste or tape?
Old July 19th, 2008, 09:44 AM   #17
86_Notch's Avatar
1986 lx notch
9.98 @ 135
paste , don't use tape
Old July 19th, 2008, 10:27 AM   #18
1BADSTANG's Avatar
how tight do i go? a little oomph after it wont turn easily anymore?
Old July 19th, 2008, 10:45 AM   #19
86_Notch's Avatar
1986 lx notch
9.98 @ 135
just snug it, once everything's installed you can turn the key on ( don't start the car ) and check for leaks
Old July 20th, 2008, 03:56 PM   #20
1BADSTANG's Avatar
Oh i have one more question, to get the psi gauge in my car what do i buy? Is there a kit? just the psi, i have fuel and oil gauges in my cowl. I want it do be like no bigger than a couple inches. Does it T off of the nitrous bottle out? Like a T and then a line and you put it whereever you want? I dont have a lot of money left so i hope to find something for under 100 that will suffice. Even if its used..
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/80783-installing-nitrous-tomorrow.html
Installing nitrous tomorrow - Page 2 This thread Refback July 20th, 2008 09:07 PM
Installing nitrous tomorrow This thread Refback July 18th, 2008 09:33 PM
Threads Similar to: Installing nitrous tomorrow
installing this tomorrow,hope it fits tom2000r 99-04 16 May 28th, 2008 02:22 PM
Installing tomorrow! and my gas mileage! Top Gear V6 Mustangs 27 September 30th, 2007 10:23 AM
Installing Edelbrock Direct Port Nitrous System on a Vic Jr. 99mustang232 General Tech 0 March 24th, 2006 11:00 PM
