Headlights Grounds
LinkBack (1) Thread Tools
Old July 18th, 2008, 10:17 PM   1 links from elsewhere to this Post. Click to view. #1
tehdwarvenn's Avatar
tehdwarvenn is on a distinguished road
Send a message via AIM to tehdwarvenn
Headlights Grounds
Alright, before you say anything, yes i did search the forums. Can't find exactly what i am looking for though.
My problem: Headlights/parking light are REAL dim (always have been). Fog lights are nice and bright since i did the old jury rig thing so they come on with the parking lights. When i did this, it didn't cause the problem with the dim lights so don't suggest it. Every once in a while, randomly, the headlights will go real real dim and the blinkers also don't work. It's comparable to the brightness of having an l.e.d. flashlight taped to the front of the car.
Solutions I found so far: Bad grounds (most likely)
What I am asking for: Can anyone show me a picture or describe to me where ALL of the grounds for the headlights are? Also, the passenger side is a little dimmer than driver's side.
Any suggestions appreciated.
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
Old July 19th, 2008, 12:04 AM   #2
nudge
Old July 20th, 2008, 12:00 PM   #3
nudge again...
Old July 20th, 2008, 12:23 PM   #4
tmoss's Avatar
tmoss is on a distinguished road
they ground up front - follow the black ground wire to the location. Take the ground off and check for corrosion and a tight fit.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old July 20th, 2008, 01:03 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
They ground to the header panel. a black wire, one on each side, next to the hood rubber snubbers. Kinda on each side of the hood prop rod.
Old July 20th, 2008, 01:05 PM   #6
ok found em, unscrewed em, sanded em (lot of paint on em), put em back on tight.
headlights dont randomly dim anymore, my volt meter (cant say its accurate) reads a constant 9.5ish 10 and the starter seems weak when its starting. alternator problem? cause once the car is started, power seems fine. and i have a new Everlast Maxx in there... (2 months old)
Old July 20th, 2008, 01:09 PM   #7
JBIGBOOTSY's Avatar
1990 LX hatch
cheapest first.
1) bat. cables
2) starter solenoid
3) starter
4) alt.
Old July 20th, 2008, 01:58 PM   #8
tmoss's Avatar
When I pulled the bolt for my neg battery cable out of the timing cover, the threads in the cover were corroded to hell and I was having starter drag too. Moved the ground to the head and problems were over.
Old July 20th, 2008, 02:38 PM   #9
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
It's a good idea to add some more grounds from block to frame.
The single ground strap on back of driver side head is not enough.
I upgraded and add to ... my battery to block, battery to body and block to body
and it helped a lot.
and the stock 75amp 2G alternator is weak to start with.
130amp 3G alternator upgrade is always
btw: if you are running U/D pullies, they just make this problem worse by
slowing down the alternator.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/80814-headlights-grounds.html
Headlights Grounds This thread Refback July 19th, 2008 08:58 PM
Threads Similar to: Headlights Grounds
Headlights HTK241 99-04 16 February 14th, 2008 03:39 PM
Headlights... 00GT MuscleBlack V6 Mustangs 11 August 4th, 2007 12:22 AM
new headlights on the way 91foxhatch5.0 Visual 2 June 10th, 2007 10:33 AM
Grounds jonnotch 5.0 Mustangs 3 June 3rd, 2007 04:37 PM
Carlisle Fair Grounds All Ford Nationals D-Brow The Clubhouse 9 May 2nd, 2007 05:40 PM
