LinkBack (1) | Thread Tools |
#1
89 lx
race gas question
i was wondering if i put some vp race fuel that a sunoco sells at the pump near my house, if i but up the timing will i see a big difference? my car is a 89 lx fairly stock, typical intake, edelbrock mass air meter, headers, catted h-pipe, flowmasters.... and if so how much timing should i advance it???
1992 Lx
11.39@119.24
whole points so you can run more timing/boost without detonation, i highly doubt itll help you at all
89 lx
run more timing... like i said, u dont think it will show any difference?
1992 Lx
11.39@119.24
personally, no, i dont, but let a more experienced member chime in
1979 mustang 5.0
hopefully 11's when complete
what is this "race gas" is it just the ultra 93??? Or is it $7.00 a gallon CAM II 110 leaded????
if it's just the 93 octane I really doubt you'd see a difference worth your while.... Pretty sure it tells your to put a minimum 91 octane in those anyway from the factory right?
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO |
1990 LX hatch
Leaded gass and cats dont mix, also, over time it will kill your O2 sensors.
EVO 8 @ 29psi
oh reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeealllllllllly yyyyyy
2003 EVO 8 The shop built motor, Precision 6262 w/.82 hotside, tial 44mm wg, Buschur RACE 4" FMIC, Kelford 272s etc 524whp @25psi on straight pump gas. 640whp@33psi Pump+meth Race gas number soon. TheShopCt.com |
EVO 8 @ 29psi
gimme some bologna skins and a tank of cam II and ill wipe your ass all over the place
1990 Mustang GT
13.64 @ 101 MPH
race gas burns slower than regular so it is more efficient in the combustion process. more timing will make more power but not worth paying fer race gas IMO without more mods. and to answer yer ? yes it would allow you to run more timing but its just not worth the $$$ at the pump
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
#10 | |
1990 LX hatch
1990 Mustang GT
13.64 @ 101 MPH
true. because you need more timing, boost or somethin else that will make it start burning sooner because it does burn slower. if not it will not burn enough and in result will be like retardin yer timing, the gas wont have enough time to burn and the "explosion" will try to push against the rotating mass. and i think the word i was looking for was combustible. not efficient. my bad.
89 lx
the fuel i was refurring to is 110 octane, so to sume up everyones answers, the answer is yes but for a fairly stock car it wont be worth the price.... also how well does 110 octane and nitrous work together?
Yes, bumping the timing will allow you to use higher octane fuel. That is how tuners and chips work. They bump the timing to allow you to burn higher octane fuel which in turn is more efficient which means better mileage and more power. Bumping timing and using low octane fuel means the explosion will occur too soon and cause detonation. Not bumping the timing and burning high octane fuel means the explosion is occuring too late. Meaning the piston will be on the downstroke already and less compression in the cylinder= less power and poorer fuel economy.
1989 Mustang Gt
Run me and find out!!!
its not worth it to run race gas in a street car....especially a pretty much stock car... I run 93 octane in a 331 that makes 500 + hp... of course its tuned for 93 octane but like mentioned above not worth it... use the extra 2-3 per gallon and save for a supercharger or other mods
110 is usually leaded fuel.
that is a nono. For one it is illegal to use on the street. For two it will ruin you O2s and your car will run rich from then on If you have a carb, then it's a different story.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
2002 Gt
Not Slow
![]() iTrader: 1 reviews
i use 100 from time to time,... car is slightly more responsive, and mpg goes up,.. the higher the octane the less gas it takes to make the same power
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
89 lx
without tuning on a dyno how much can u advance your timing while being safe while on 93 octane, 100 octane?
1990 LX hatch
If your engine does not require the higher octane fuel, the fuel will do nothing for you. In fact you will probably lose a few horsepower. On a stock 9:1 compression 5 liter you will never see a benefit from race fuel even when you advance the timing. Race fuel is for high compression or forced induction or heavy nitrous engines. That is where you will see a difference in timing, not on a 9:1 compression naturally aspirated engine.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/80924-race-gas-question.html
| race gas question | This thread | Refback | July 20th, 2008 10:46 AM | |
Threads Similar to: race gas question
| indy 500 drivers upset: gas price rose 3 times during race | vfast | The Clubhouse | 5 | May 28th, 2008 08:19 PM |
| 110 leaded race gas...? | workinprogress | 99-04 | 22 | March 14th, 2008 12:20 PM |
| can someone explain these tuned for 100 race gas tunes??? | nba1341 | 2005 - 2010 | 3 | July 28th, 2007 09:56 AM |
| So (Race Question) | einod | V6 Mustangs | 36 | September 22nd, 2006 01:22 AM |
