What is the power band like on the 90 5.0s?
Old July 21st, 2008, 01:11 PM   #1
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
My buddy got one a months or so ago and says peak power is at 4500rpm, which I think is BS, cuz thats way low. Anyone have dyno charts of stock, or mostly stock 5.0s?
Old July 21st, 2008, 01:22 PM   #2
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
the STOCK 5.0's die at higher rpm's!
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old July 21st, 2008, 01:39 PM   #3
1992 Lx
11.39@119.24
i shifted at 5500 with just my explorer intake, seemed to pull till that rpm
Old July 21st, 2008, 02:00 PM   #4
Blown 03 GT
whos got a dyno sheet?
Old July 21st, 2008, 02:03 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
I don't have any stock charts around but I'd say it is even lower than 4500. The torque in a stock 5.0 from a Mustang would be great match in a truck
The average torque and HP from the 5.0 is good and better then the "peak" numbers would lead to to believe.
Old July 21st, 2008, 02:32 PM   #6
1989 Mustang Gt
there is a sticky in here that is labeled destroying dyno myths go look at it 03...
I love pink
Old July 21st, 2008, 02:34 PM   #7
95StangMX's Avatar
95 Mustang GT
took the letters right off of my keyboard i almost posted the same thing
Old July 21st, 2008, 02:35 PM   #8
95StangMX's Avatar
95 Mustang GT
from what i was seeing on there stock should peak at about 48 to 5 grand
Old July 21st, 2008, 02:42 PM   #9
Blown 03 GT
Thanx that helps, and I was right he says he shifts below 5 grand which is way too low, he should def be shifting around 5500
Old July 21st, 2008, 03:16 PM   #10
1989 Mustang Gt
You smoke crack right?....lol jk... makes peak power from 4300-4800 and peak torque I believe at 3500... he sholud be shifting aorund 5 grand...
I love pink
Old July 21st, 2008, 03:42 PM   #11
Blown 03 GT
My bad I was lookin at one of the tables for mods, so 5 grand it is.
Old July 21st, 2008, 04:27 PM   #12
The Razor's Edge
White Thunder's Avatar
i say still shift at 5500 then you come right back into the powerband strong
founder of the FTN Club
Old July 21st, 2008, 04:35 PM   #13
1989 Mustang Gt
i might be mistaken but I would assume you shift just as your power starts decreasing because the rate of acceleration changes to a slower rate as the power drops... so you wouldnt want to run it too far past the peak power rpm... after you shift you go back to raisng the rpms... so if you keep the rpms up high it would cause a slower elapsed time
I love pink
Old July 21st, 2008, 04:48 PM   #14
Blown 03 GT
I always thought it was best to shift so the you have the most average power, in this case shifting at 5 grand would keep you the most power.
Old July 21st, 2008, 04:53 PM   #15
1989 Mustang Gt
that makes sense...
I love pink
Old July 21st, 2008, 04:56 PM   #16
Blown 03 GT
that makes sense...
you being serious?
Old July 21st, 2008, 06:18 PM   #17
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
In my opinon you shift really high in first like 5,800-6000 like 5300 in second and like 4800-5000 in the higher gears. From my exp at the track this worked best for my stock 5.0
Old July 21st, 2008, 06:30 PM   #18
1989 Mustang Gt
shift points are determined by the modifications on a car...Ive never ran a bone stock 5.0 so i couldnt tell you from experience how to get the best e.t.
I love pink
Old July 21st, 2008, 11:01 PM   #19
The Razor's Edge
trail and error.....i think how you shift...when you shift...and the condition of your motor should change it for every car / driver
Old July 22nd, 2008, 03:47 AM   #20
KansasCityGT's Avatar
1995 Mustang GTs
KansasCityGT is on a distinguished road
Send a message via AIM to KansasCityGT
If you're running stock key components, heads, cam, rockers, intakes ect. Your shift point should be between 4500 to 4700. Around 4800 the valves start to float. Obviously, if you are spinning, wait to get traction then see where you're at. Try going to the track and shift at different rpms, see what works best w/ your car. If you don't mind spending the money or a shop has a cheap dyno day, see where your peak hp is.
Threads Similar to: What is the power band like on the 90 5.0s?
videos of my band! 00gtCoolGuy The Clubhouse 11 February 25th, 2008 10:45 AM
Tool The Band MustangMatt96GT The Clubhouse 33 November 21st, 2007 02:19 PM
the band Saliva gooberhead320 The Clubhouse 6 August 11th, 2007 02:37 PM
Good band 2000Mustang The Clubhouse 3 May 13th, 2007 11:26 PM
