Short stroker, large bore/ Long Stroke, small bore
Which is better? Im in the planning stages of a 360 ci... 3.25 crank or 3.4?
1989 Mustang Gt
Run me and find out!!!
doesnt the smaller stroke rev quicker???
yes the smaller the stroke, the faster it revs up
If you want to run alot of boost or run an efficent boost set up , the smaller stroke will help with the boost. A larger stroke as in either a 331-347 wont be essential for boost. A lot of fast drag racers prefer a 302 bored to a 306, and run alot of boost. A Nice DSS 306 is a great setup. PaT #06 |
1989 Mustang Gt
larger bores promote better breathing... but will the difference b very evident in the situation that 331 stang stated? a 3.25 crank with a standard 4.185 bore makes 357.6 ci and a 3.4 stroke with a standard 4.125 bore makes 363.5 ci... assuming the same supporting hardware (intake, cam, etc.) which makes the quicker e.t?
1990 Mustang GT HO
N/A
Stroke it
Iv'e Always Appreciated the Big bore,Short Stroke
1989 Mustang Gt
me too... but is there enough of a difference to choose the shorter stroke in the application 331stang mentioned? for discussion purposes...
1990 LX hatch
The more power an engine makes, the faster it revs. the short stroke/high rpm idea, really dosent determin the rev abilitys of an engine. The valvetrain does.
1989 Mustang Gt
so the engine with the most power will always accelerate faster?
1990 LX hatch
Yes. When it comes to a car engine. No. if you comapre a race engine to a Dremmel.
1989 Mustang Gt
so in the case of the 3.25 crank vs the 3.4 in larger bore motors they rev relatively the same seeing as how a 357 and a 363 would make about the same hp.
Large bore is better than a small bore in most cases because it unshrouds the valves more than a small bore does. Run the largest stroke that the heads will keep up with. More cubes equal more power unless the heads can't keep up with the airflow requirements.
Thanks Darrell, that was the info I was looking for.
1987 ford mustang gt
well see when shes done
What kind of block are you going to be using?
#15 | |
#16 | |
Both are good heads. Just make sure if you have any porting done have it done by a reputable shop like TEA.
Because its not true. Cubic inches makes horsepower plain and simple. Those guys are running 360 inch engines because rules allow it and they can make more power with the bigger engine.
thats what I was thinking...
Threads Similar to: Short stroker, large bore/ Long Stroke, small bore
| bore | gooberhead320 | V6 Mustangs | 5 | May 11th, 2008 06:02 PM |
| bore | Iownastang | 5.0 Mustangs | 11 | February 5th, 2008 11:18 PM |
| whats the bore and stroke? | superman5.0 | 5.0 Mustangs | 12 | August 13th, 2007 12:36 AM |
| new engine or bore and stroke | 88speedracer | 5.0 Mustangs | 5 | April 11th, 2007 11:01 PM |
| Bore Size | cali 5.0 | Modular Mustangs | 8 | November 1st, 2006 03:00 AM |
