Sensor Question
Old November 17th, 2006, 07:27 PM   #1
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
Sensor Question
I am trying to track down the ACT sensor. does anyone know where this is? and its primary function?
Old November 17th, 2006, 08:59 PM   #2
82GT is an unknown quantity at this point
It should be located in the lower intake on the driver side near #5 cylinder. It purpose is to modify ignition and fuel signals.
Old November 18th, 2006, 03:46 PM   #3
cobraetti's Avatar
2001 svt cobra
no way (IRS)
Thanks, if it is in fact faulty what could be the result?
Old November 18th, 2006, 03:58 PM   #4
TENGRAM is on a distinguished road
inaccurate and less than optimum timing and fuel calculations...possibly even "limp" mode
89 GT t5 3.73
www.my5oh.com/
Old November 18th, 2006, 06:32 PM   #5
cobraetti's Avatar
2001 svt cobra
no way (IRS)
can anyone show me a diagram of this sensor location
Old November 18th, 2006, 06:56 PM   #6
I don't have a diagram but it should be in the #5 intake port of your lower intake. I'll look to see if I can find you a diagram. It threads in.
Old November 18th, 2006, 07:21 PM   #7
the upper intake is removed for photo purposes but does not need to be removed to remove or replace the ACT sensor. the sensor is just behind and to the right of the distributor if you're looking from the front of the vehicle.
89 GT t5 3.73
www.my5oh.com/
Old November 18th, 2006, 07:31 PM   #8
cobraetti's Avatar
2001 svt cobra
no way (IRS)
thank you kindly,that is a huge help
Old November 29th, 2006, 10:44 PM   #9
chadjones99's Avatar
chadjones99 is on a distinguished road
what is a act sensor
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Old November 30th, 2006, 01:09 AM   #10
See second reply above
1982 GT (t-top)
351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's
Best E.T 12.85@102mph
Old November 30th, 2006, 01:39 AM   #11
air charge temperature sensor...it "measures" intake air temperature so the computer can make fuel and timing adjustments accordingly.
89 GT t5 3.73
www.my5oh.com/
Threads Similar to: Sensor Question
'97 olds 88ls sensor question. noob All Other Vehicles 3 July 2nd, 2007 04:12 PM
Oxygen sensor question MnrlGry01gt 99-04 3 June 2nd, 2007 02:17 PM
O2 sensor question Tony_90fox 5.0 Mustangs 18 December 13th, 2006 09:23 PM
MAP sensor ROBBED666 2005 - 2010 0 October 9th, 2006 04:12 PM
MAF sensor 5.0 Rono 5.0 Mustangs 2 July 16th, 2006 09:51 PM
