93 5.0 camshaft suggestions for a carburetor engine
Does anyone have a suggestion for a mild camshaft for a 5.0 carburetor engine?
1989 Mustang Gt
Run me and find out!!!
is it stock?
Yeah, bone stock, in a couple of years I want to stroke it a 347, so I just want something mild now.
1989 Mustang Gt
its old technology but a b cam is decent...
1983 mustang lx
if youre converting a 93 efi motor to a carbed motor, youre going to need an 85 distributer with a steel gear, a cast gear will get eaten up up and cause a big ol failure
If I get an e303 cam, do i still need the steel gear?
1983 mustang lx
i think the e303 has a steel gear, so yes.
dont fear about finding an 85 distributer with a steel gear. i went to napa and had them order one for me and it cost me like 50 bucks, but i also gave them the original distributer. advanced auto and any other place will be able to order you a distributer like that as well i believe 1985 was the first year they started putting steel gears on the cams and it was also the last year for carburated motors. |
1990 foxbody
14.8@98mph
i just went to the junk yard and found an older distributor and put in my car but i have yet to change the gear and i know that i need to soon
your always faster then the guy in the mirror |
DO i need a module for the 85 distributor?
1989 Mustang LX
10.98@126.7 NA
You can use Ford's Dura-Spark module with the '85 distributor or an aftermarket like MSD 6AL. Make sure the gear is steel on the distributor because there were cast gears used on non-roller motors. If you get a reman from AZ or pep boys etc. double check the gear as well.
Never fast enough.
I currently have a 289 in my 67, I am going to use this 302 in it. Can I just use the same distributor and change the gear? The distributor is not all that old. Is it possible to use the gear for the distributor that I removed from the 302?
1990 Mustang GT
13.64 @ 101 MPH
if you have an older style dist. either vac or mechanical advance, you can just knock the pin out at the bottom and take the gear off then put on yer steel gear. make sure you use a new pin tho
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
great, thanks for the tips guys
Threads Similar to: 93 5.0 camshaft suggestions for a carburetor engine
| 4.6L engine swap.. Any suggestions? | danh0gan | All Other Vehicles | 5 | April 4th, 2008 01:53 AM |
| 4.6l engine swap.. Any suggestions? | danh0gan | 96-98 | 9 | April 1st, 2008 08:15 AM |
| 4.6l engine swap.. Any suggestions? | danh0gan | Modular Mustangs | 2 | March 31st, 2008 10:30 PM |
| Camshaft suggestions | 6stang | V6 Mustangs | 1 | February 4th, 2008 01:04 AM |
| Need some suggestions (engine) | Spiderz | Classic Mustangs | 11 | April 30th, 2007 01:08 PM |
