no oil pressure
Old July 22nd, 2008, 08:53 PM   #1
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
no oil pressure
I have an 82 5.0 i just recently had to put a new top end on it because of 12 snapped off bolts. the top end is a set of e7 heads off of an 89 5.0 and a dual plane intake with a holley 650 double pumper on that. my question is my oil pressure at idle is now absolutely nothing and while driving it only goes up a little bit...could be a bad oil pump or is it the sender.
Old July 23rd, 2008, 10:13 AM   #2
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Connect a mechanical gauge to know exactly what pressures your carrying and go from there. Are you sure the drive rod from the distributor to the oil pump is in place?
Never fast enough.
Old July 23rd, 2008, 12:11 PM   #3
Smirnoff's Avatar
1982 GT t-top
im pretty sure the drive rod is in place it felt like it went in when i was putting the distributor in
Old July 24th, 2008, 02:52 PM   #4
Smirnoff's Avatar
1982 GT t-top
ok so i hooked up a mechanical guage and im only runnin 10 psi at idle. is that enough ?
Threads Similar to: no oil pressure
Oil Pressure???? sn94 5.0 Mustangs 1 July 23rd, 2008 09:16 AM
Oil Pressure sstang 99-04 2 March 16th, 2008 06:00 PM
oil pressure oasr87 V6 Mustangs 4 July 16th, 2007 12:40 PM
Oil Pressure fordpat General Tech 1 December 2nd, 2006 04:21 PM
oil pressure turp V6 Mustangs 1 August 19th, 2006 11:59 AM
