Long Tube Header Install?
Old July 23rd, 2008, 08:03 AM   #1
Toofer89's Avatar
1989 Mustang LX
Toofer89 is on a distinguished road
Hey, I am going to be getting some long tube headers in the near future and I was under the impression I could install them but I have been reading some other peoples experiences and it seems a lot more involved. So I have an 89 5.0 LX and was wondering if you guys have installed them on your cars? and if so what steps/procedures did you have to do. Are there any brands that are better than others ect. Just don't want to get over my head and if it seems to complicated for me I'll just have the shop do it. Thanks for any impute/stories/thoughts you have on this.
Mike
Old July 23rd, 2008, 08:49 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The factory headers come off easy. Once you get them off take the nut off of each engine mount so you can jack up the engine. A floor jack and a block of wood on the crank pulley will lift the engine enough to slide the headers in from the bottom. With a little patience and geometry it is a fairly easy job.
Old July 23rd, 2008, 11:38 AM   #3
Toofer89's Avatar
1989 Mustang LX
I do have access to a car lift... will that help me at all? idk how i could jack the engine up if the cars up though
Old July 23rd, 2008, 11:43 AM   #4
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
just put the car on jack stands so you can lift up the engine.
Engine has to be lifted up an inch or two to get LT's on/off.
Drivers side header is the real bugger to get on around the steering shaft.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old July 23rd, 2008, 03:18 PM   #5
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
You'll probably have to disconnect the steering shaft also.
Old July 23rd, 2008, 05:34 PM   #6
1990 Mustang GT
13.64 @ 101 MPH
GoodOleBoyzRacin is on a distinguished road
if you do it on the lift, you can either jack the motor up some while its still on the ground and use a hoist that goes across the strut towers, or from underneath use a screw jack. its fairly easy to do if you have access to those things. i dropped in mine when i dropped in the new motor.
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8
Old July 24th, 2008, 05:12 AM   #7
Toofer89's Avatar
1989 Mustang LX
Any suggestions on mid pipes? I already have a flowmaster after cat I had to put in because the original one was rotted out
Old July 24th, 2008, 07:38 AM   #8
91cobra5.0's Avatar
98 Cobra
i have long tubes as well and have an o/r H into flowmasters and it sounds great, oh and i did not have any clearance issues with the steering shaft
Old July 24th, 2008, 08:26 AM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Get a H or X pipe that matches the headers you buy. BBK and MAC make headers and H/X pipes with or without cats.
Old July 24th, 2008, 02:10 PM   #10
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
an easy way if your using a car lift is to lift the car, unbolt the the motor mounts, then use a screw jack on the crank pully, basically what darrel said.
Old July 24th, 2008, 03:23 PM   #11
91cobra5.0's Avatar
98 Cobra
i pulled my tranny and bellhousing to get em in, and i dont recomend it, it takes too long, i didnt know about the jack thing or i would have gone that route
Threads Similar to: Long Tube Header Install?
Long Tube header questions... joeice14 2005 - 2010 23 June 30th, 2008 08:52 AM
h pipe and long tube header ummmbaby741 2005 - 2010 V6 4 June 4th, 2008 07:27 PM
Long tube header help! 1997Stang 96-98 2 May 2nd, 2008 09:05 AM
Long tube header question Badasstang281 99-04 4 February 2nd, 2007 10:49 PM
Long Tube header Install Write-Ups? xx9gt6xx General Tech 2 April 27th, 2006 03:12 PM
