98 Cobra
what numbers do 351w make?
what kind of numbers dose a stock 351w make?
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
I would guess anywhere between 50 and 3500 HP depending on the set-up. What exact kind of build are you talking about here?
Less than a 5 liter HO. Most 351W were turds from the factory. They use the same heads as a 302.......just a poor all around engine.
98 Cobra
id assume the block is stronger?? since a lot of people use them high power producing number engines. would you be able to stroke out a 351w and make a good N/A motor out of it?
you can stroke a 351w out to a 427. you would need to do some serious work to the heads though but it would be about 450hp, I would not use anything but a sportsman block. they are stronger. we had a guy in my shop take and build a 454 out of a 351w sportsman, it lasted him a couple of months. it was efi and it sound amazing and ran even better
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer Last edited by beheivjer; July 24th, 2008 at 10:13 AM. |
The set of heads i found that would flow right would end up costing me about 1500 when done
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
1989 LX Vert - 1993 Notch
Fast
"stock" 351 is a truck engine.
make more torque than hp. my N/A 351W with .030 over for 357ci, 10.3-1 compression AFR185 heads and off the shelf CompCams cam made 365rwhp at 6,000 rpm. Simple H/C/I swap on 351W will wake those engines up in to the 450-500hp range easy. Unless you plan on making over 500rwhp the swap is not worth the trouble though. stroked or blown 302 will make that with half the headaches.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
Yes the block is stronger and yes it will support some relatively large horsepower numbers both N/A and with a power adder.
a sportsman block is alot stronger if building for max power on it
a carbed 351w was rated at 150-160hp net ratings 250 hp gross rating
efi is rated at 200-235 hp
98 Cobra
well im asking becuase when i come get back home to california in about a year and a half id like to build a 65-69 mustang with a big all motor engine. but of course this would be a bit of time from now but id still like to start planing and saving
Fast
Cant wrong with a high compression, big head, big cam 408W.
right combo will push 500rwhp N/A
98 Cobra
is it hard to get over 500 n/a? no juice
93 LX Conv
dead slow!
I know a 351 stroked to a 408 makin 500 to the crank? No boost anybody want the number to where she sits, let me know...
Fast
depends how streetable you want the cam.
It's not hard per say, but you'll have some compromises in low end idle and such. 11-1, Solid roller cam 408W with nice big heads and everything built to spin the motor to 6,500-7,000+rpm would probably break 500rwhp. 500 crank hp is easy. My 357ci made 475hp at 6,000 rpm on engine dyno with relatively mild parts.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us Last edited by r.barn; July 24th, 2008 at 03:59 PM. |
#16 | |
93 LX Conv
dead slow!
500hp at the crank or wheels. 500hp at the crank is easy. 500hp at the wheels is going to take a bit more.
93 LX Conv
dead slow!
I'll guess at crank, only because unless you add a power adder. You will be at a teed bit over 500. Like I know (for a fact) where your going to get the most out of that combo. Not trying to be a know it all, but then I would hate to free advertise for this engine builder, and get my A$$ booted off here. This motor has well over 35 grand in it.. (you have to figure all the testing involved, and etc) Sad thing the guy has given up on this project,I was trying to call him to buy it off him, and failed due to out of service numbers.
#19 | |
#20 | |
93 LX Conv
dead slow!
Threads Similar to: what numbers do 351w make?
| 351W casting numbers | 92sspnotchback | 5.0 Mustangs | 7 | June 15th, 2008 01:29 AM |
| can you make a 351w smog legal without killing the power? | 97S281 | 96-98 | 1 | February 24th, 2008 12:54 AM |
| what do u think the numbers will be? | blue03mach1 | 99-04 | 40 | June 24th, 2007 12:22 PM |
| HP numbers 99-04 | tording92lxnotch | Modular Mustangs | 30 | April 22nd, 2007 05:49 PM |
