Ok ready to get flamed!
LinkBack (1) Thread Tools
Old July 24th, 2008, 12:00 PM   1 links from elsewhere to this Post. Click to view. #1
95StangMX's Avatar
95 Mustang GT
I know you guys are probably gonna light me up on this one.....I have a CHP 347 stroker kit with probe pistons and trick flow co1's heads anybody know what compression I should be at? or what other specs do you need to know?
Old July 24th, 2008, 12:02 PM   #2
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
10 something
11-1
Old July 24th, 2008, 12:09 PM   #3
93 LX Conv
dead slow!
boostjunkie is on a distinguished road
11-1, or 10! It really doesn't help me I could use some specs?
Old July 24th, 2008, 12:27 PM   #4
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
need piston dish size
cylinder head combustion chamber size
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old July 24th, 2008, 12:38 PM   #5
ryans88gt's Avatar
head gasket used (bore and thickness)
piston to bore clearance
Piston to deck clearance
cylinder chamfer
Old July 24th, 2008, 12:45 PM   #6
93 LX Conv
dead slow!
Old July 24th, 2008, 01:06 PM   #7
Holy Dick Castle!
dr.gonzo!'s Avatar
what about this one?
Old July 24th, 2008, 01:21 PM   #8
93 LX Conv
dead slow!
No this?
Old July 24th, 2008, 02:25 PM   #9
qwkvert's Avatar
1989 lx convertible
10.87 @ 128 ( old 302 combo)
qwkvert is on a distinguished road
just call CHP and ask them....but be prepared to tell them the head gasket and heads you are using. they are the only ones who will tell you for sure without breaking out some measuring tools to find out how far in the hole you are, if the deck has been milled etc...........
A bigger motor with a lot of parts they said would make me go faster......
Old July 24th, 2008, 03:28 PM   #10
Fast
you can get with in 1/10th of the right number with just
piston dish and combustion chamber and guessing some of the other
numbers like 0 deck height, .039 compressed head gasket and .030 over bore, ect.
That will get you close enough for the most part.
There are tons of online calculators to put the numbers into
God Help Us
Old July 24th, 2008, 09:09 PM   #11
95StangMX's Avatar
95 Mustang GT
thanks....woody kinda put together the combo so I am sure I can just call him but wanted to know how to figure it but sounds like a pain in the ass so I think I will just ask....lol
Old July 24th, 2008, 09:10 PM   #12
95StangMX's Avatar
95 Mustang GT
what compression range do I want to be in to run a 1-150 shot of gas?
Old July 24th, 2008, 09:58 PM   #13
91cobra5.0's Avatar
98 Cobra
is it better to run thicker or thinner gaskets?
Old July 25th, 2008, 01:24 AM   #14
fogged306's Avatar
89 GT
You don't have to worry about compression as much with nitrous as you would with boost. You'll be fine, just back the timing off a couple degrees.
Old July 25th, 2008, 09:55 AM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Assuming a flat top piston at zero deck and a standard .040 thick, 4.100 bore head gasket you will be at 9.75:1.
Old July 25th, 2008, 09:55 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Doesn't matter at all.
Old July 25th, 2008, 04:37 PM   #17
95StangMX's Avatar
95 Mustang GT
the numbers on the pistons are as follows 1.175/4.030/.912/-4.0cc does that help... and darrel or anyone else know is there a certain size head gasket I should run?
Old July 25th, 2008, 07:12 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I figured a -6cc valve relief on a flat top piston so the -4cc changes things a bit. Assuming zero deck and a standard .040 thick x 4.100 bore head gasket you will be at 9.97:1.
Standard head gaskets will be fine. If you want more compression, mill the heads.
Old July 25th, 2008, 08:08 PM   #19
ryans88gt's Avatar
Thin gaskets are not great b/c they do not seal well. Gaskets thicker than 0.050 cause excessive detonation due to loss of quench.
Old July 25th, 2008, 08:15 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
The quench area is a big issue that nobody ever thinks of.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/81568-ok-ready-get-flamed.html
Ok ready to get flamed! This thread Refback July 24th, 2008 12:19 PM
Threads Similar to: Ok ready to get flamed!
I'm about to get hardcore flamed... Dansby The Clubhouse 13 April 5th, 2008 02:20 AM
I'm ready to do it gooberhead320 The Clubhouse 69 April 2nd, 2008 08:52 PM
All ready! JASonic The Clubhouse 7 March 23rd, 2008 01:20 AM
tell me are you ready? nba1341 The Clubhouse 9 February 25th, 2008 06:01 PM
whose ready for some ... thetrooper31 The Clubhouse 30 September 8th, 2007 11:14 PM
