timing?
Old July 24th, 2008, 05:58 PM   #1
5.0Madness's Avatar
1994 Mustang GT
5.0Madness is on a distinguished road
timing?
ok I have a problem, Im trying to bump my timing up to 14, but I cant find any marks on the harmonic balancer and have no idea where to make new ones
Mac CAI, flowmaster 40-series mufflers, Steeda shortthrow shifter, Mac O/R H-pipe
Old July 24th, 2008, 06:00 PM   #2
93 LX Conv
dead slow!
boostjunkie is on a distinguished road
Why 14? Hope I can help...
Old July 24th, 2008, 06:10 PM   #3
5.0Madness's Avatar
1994 Mustang GT
becus it should run better with the timing bumped up to 14, I just cant figure out how to do that
Old July 24th, 2008, 06:13 PM   #4
93 LX Conv
dead slow!
Can you at least do 15!! You got mail....
Old July 24th, 2008, 06:15 PM   #5
5.0Madness's Avatar
1994 Mustang GT
wtf?
Old July 24th, 2008, 09:16 PM   #6
95StangMX's Avatar
95 Mustang GT
believe you bring the number one piston to the top and put a mark on the top of your harmonic balancer....not positive on that....if you cant see the marks just pull the spout connector and move the dizzy a little and drive it...if you are detonating (pinging noise) back it off a little at a time till it stops....
Old July 24th, 2008, 10:35 PM   #7
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
get a timing light with a knob ( i've got a relatively cheap ACTRON timing light that i got at autozone ) , then all you need to do is to make 1 mark on the balancer at 0 and adjust the knob, i've found that to be much easier then trying to read the balancer or making more then 1 mark on it ( my eyes aren't the greatest anyway tho )
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old July 24th, 2008, 11:30 PM   #8
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
Get a really bright floresent light and go under the car then look at the balancer. I couldnt see any number with a normal flash light but as soon as I put the timing light to it I could see it very clear. You may have to hit it with some solvent and a rag...
Old July 25th, 2008, 05:05 AM   #9
JBIGBOOTSY's Avatar
1990 LX hatch
Originally Posted by 86_Notch View Post
get a timing light with a knob ( i've got a relatively cheap Laser ray gun, it kills aliens, and zombies ) , then all you need to do is to make 1 mark on the balancer at 0 and adjust the knob, i've found that to be much easier then trying to read the balancer or making more then 1 mark on it ( my eyes aren't the greatest anyway tho )
fixed
Old July 25th, 2008, 06:56 AM   #10
86_Notch's Avatar
1986 lx notch
9.98 @ 135
Originally Posted by JBIGBOOTSY View Post
fixed
hehehe, i like that
Old July 25th, 2008, 09:44 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Clean the balancer. The numbers are there but most likely they are dirty or have a small layer of rust over them.
Old July 25th, 2008, 10:54 AM   #12
fox bodies rule is on a distinguished road
before you go nuts trying to find the timing marks and doing what has been suggested may I suggest that you determine if your balancer is any good?The stock ones are notorious for the rubber islolater ring tearing and the timing marks slipping around to where they shouldn't be. If it isn't obvious to you that the balancer is toast try to wiggle it or turn it by hand. If you get any movement at all or find rubber hanging out where it shouldn't be, you have found your problem and can proceed from there- if you aren't comfortable that you have determined the status of the balancer, try findiing TDC. Be careful here, there are two TDC's in play per complete cycle so you need to know that both valves are closed when the piston is at TDC, that one is where you should be able to see the 0 on the dampner. If you need more help, pm me and I can walk you through the whole process
Old July 25th, 2008, 01:21 PM   #13
Hunt_chevs's Avatar
2002 Gt
Not Slow
+1, when i did my timing i had to get down there and rub/wipe the balancer b4 i could see any marks on it what so ever. Than you should be able to see and place a mark on it down there
Old July 25th, 2008, 07:22 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1 on the possibility of a bad stock balancer.
Threads Similar to: timing?
go up in timing? tarpeeler 2005 - 2010 1 July 18th, 2008 03:53 PM
timing hopper 5.0 Mustangs 10 July 8th, 2008 06:19 AM
timing patwrecked 5.0 Mustangs 5 October 10th, 2007 11:02 PM
More Re-timing help 97redgt Modular Mustangs 1 September 9th, 2007 08:24 PM
Timing help please ckjacobus 96-98 1 August 13th, 2007 05:55 AM
