fiberglass hatchs...
Old July 25th, 2008, 02:15 AM   #1
EscortSportage's Avatar
1989 Mustang GT 5.0
im trying to drop as much weight as possible in my 89 gt
was wondering how much does the fiberglass hatch that people sell, how much weight does it drop
im also planning on fiberglass fenders,doors and hood
Old July 25th, 2008, 02:38 AM   #2
e3sean's Avatar
1988 lx
9.68@142
fiberglass hatch would drop weight but make sure u have good suspension cause that weight is right over the back axels right where it needs to be and everyone knows spinnin aint winnin
<font size=4><b>MILITARY CREW
Old July 25th, 2008, 03:07 AM   #3
The Razor's Edge
White Thunder's Avatar
yeah i was going to say the same thing...i know the glass is pretty heavy as well...but if there is anywhere you want weight thats it.....
get a new k member thats about 50 lbs.....
founder of the FTN Club
Old July 25th, 2008, 06:03 AM   #4
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Cut the weight some where else.
Never fast enough.
Old July 25th, 2008, 09:47 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I wouldn't worry about taking weight out of the rear. It isn't going to hurt anything as long as your suspension works. I would definitely start with other things before I removed weight from the rear. At this point taking 50 pounds off the front will be more beneficial than taking 50 pounds off the rear. Tackle the front first, then worry about the rear.
Old July 25th, 2008, 09:48 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
There are alot of freebies too like bumper supports, misc. brackets, etc.
Old July 25th, 2008, 01:24 PM   #7
Hunt_chevs's Avatar
2002 Gt
Not Slow
+3 or so, ,, mustangs, especially fox's have super light rear ends,.. ive seen people go as far as putting more weight in the back to compensate for traction. and im not talking a little weight,.. im talking like a few sand or cement bags.
Old July 25th, 2008, 07:21 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Those people need to understand how suspensions work or have a poorly designed suspension. Dumping a ton of weight in the rear is just compensating for a poorly operating suspension. When I build a race car I take weight out from everywhere I can remove excess weight. I do not worry about front, rear, etc. Then when the car is finished I add weight back in where it needs it like the passenger side. Guys I race with have lead plates that they will add to the front of the car if the track is hooking real good and will remove them if the track is a bit slick. If weight must be added to the car to get it up to a specific weight for the class in which you are racing, then the obvious place to add the weight is in the rear. However it is not necessary to add weight to the rear in order to maintain traction. A suspension that works good will hook regardless.
Old July 25th, 2008, 07:50 PM   #9
e3sean's Avatar
1988 lx
9.68@142
put the battery in the back. tke the back seats out,get a tubular front end,take out all the insulation out from under the carpets,switch to a lighter seat,there are alot of ways to cut weight.
Old July 25th, 2008, 08:19 PM   #10
1989 Mustang GT 5.0
ok thats what i was thinking... i have already...:::
rear seat delete, ac delete, heat delete, insulation,interior, sound deadening all the interior stuff DELETE all the stuff behind the dask (duct work, ac/heat) GONE i want to put sparco seats up front, fiberglass hood, fiber glass fenders, aftermarket k-member, fog light delete, what else... i want to use lexan glass im also gutting lots of unnessary stuff from under the hood
Threads Similar to: fiberglass hatchs...
fiberglass hood cassimus Modular Mustangs 5 July 25th, 2008 10:31 AM
fiberglass riddlee josh The Clubhouse 5 April 3rd, 2008 01:40 PM
Fiberglass hoods 86_Notch Visual 0 January 17th, 2008 01:57 PM
Anyone with a fiberglass hatch? And then some 5.0 Mustangs 13 October 16th, 2007 09:33 AM
