please need help
LinkBack (1) Thread Tools
Old July 25th, 2008, 05:00 PM   1 links from elsewhere to this Post. Click to view. #1
1992 GT hatchback
ThE GhOsT RiDer is on a distinguished road
please need help
ok i have a 92 mustang gt i have removed the a/c and smog pump bought the trick flow a/c delete kit i have a k&n air filter cone on the intake i am also running off just the factory h-pipe and i have aftermarket autometer water temp oil pressure and volt meter what my promblem is that when i turn the car on the idle is at 1500 rpms and the needle is like a little bouncy. i tried adjust the idle by turning the pin on the throttle body that didnt work and i tried and replaced the idle air control valve and that didnt work. what can i do to fix this problem
Old July 26th, 2008, 03:09 AM   #2
blue90lx's Avatar
90 lx hatch
12.83@105
blue90lx is on a distinguished road
Send a message via AIM to blue90lx
See what the timing is set on, also it could just be the factory tach, may want to buy a aftermarket tach that may help a whole lot.
to many parts and money to be so slow
Old July 26th, 2008, 10:06 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Sounds like a major vacuum line was disconnected and not hooked back up.
Old July 26th, 2008, 05:49 PM   #4
1992 GT hatchback
well i removed the air box at the bottom front pass side of the engine with all the vacum lines in it and i capped the intake vacum line could that be it
Old July 26th, 2008, 09:39 PM   #5
REIGNYC's Avatar
1991 MUSTANG GT
REIGNYC is on a distinguished road
Check All Your Vacum Lines Make Sure You Did Not Disconnect The Master Also When Swapping Out Old Parts For New Understand That Once You Start You Have To Know What Other Parts For That Area Of The Engine You Are Changing Might Also Need To Be Changed ALSO LIKE THE PREVIOUS POST YOU MIGHT NEED A NEW TACK METTER AS WELL COULD BE BAD AFTER ALL ITS A MAGNET ON A STICK !!***most Of The Time Its A Vacum Line Thats Not Hooked Up Correctly***
Old July 26th, 2008, 09:47 PM   #6
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
wouldnt a mixing vaccum line cause it to idle lower and all
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old July 26th, 2008, 10:44 PM   #7
1990 Mustang GT
13.64 @ 101 MPH
GoodOleBoyzRacin is on a distinguished road
its idling higher, and eratic (bouncing around).......not lower.
spray brake cleaner around the intake where it bolts to the heads, where the upper bolts to the lower, TB, intake hose, all vaccuum lines and anywhere else intake pressure could leak from. if the engine bogs while yer sprayin it, stop and spray back in that spot. easy way to find a vac leak.....
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8
Old July 26th, 2008, 10:49 PM   #8
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
just keep in mind that if the fumes reach the leak it can mislead you to where the leak is from.... and I thought if you sprayed carb cleaner on a vacum leak it would rev up and if u use water it stumbled...i coud be mistaken though
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old July 26th, 2008, 10:53 PM   #9
1990 Mustang GT
13.64 @ 101 MPH
brake cleaner stumbles because its not as combustible, carb cleaner on the other hand would make it rev up because it is meant to go directly in/on somethin that fuel is mixed with so it has to burn.
Old July 26th, 2008, 10:54 PM   #10
1989 Mustang Gt
okay... i must have misread... i thought u were talkin about carb cleaner for some resaon... my b
I love pink
Old July 27th, 2008, 07:52 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Carb cleaner, brake cleaner and WD40 will all cause the idle to rise if you spray them on a vacuum leak.
Old July 27th, 2008, 02:49 PM   #12
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
im with him
Old July 27th, 2008, 04:21 PM   #13
1990 Mustang GT
13.64 @ 101 MPH
brake cleaner always choked my motor. maybe it cause it was the cheap kind that sprays half the can with a 3 second squirt and comes out like a water hose
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/81769-please-need-help.html
please need help This thread Refback July 26th, 2008 09:06 PM
