98 Cobra
engine light
i put a 160 degree thermostat in my car, would it through an engine light if it wasent reaching a high enough temp???? it comes on after like 10 mins then goes away as the engine gets hotter
1986 LX
none yet
shouldn't matter what size thermostat you put in.
could be the ECT sensor going bad. 160 should be a good operating temp, no reason to throw a CEL.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
98 Cobra
ECT?
1990 LX hatch
Engine Control Transistor. It's in the intake on the front driver side of the lower., there is one on the heater tube on the lower intake on the passenger side too.
98 Cobra
heater tube?, and is it twords the front of the lower or the rear, like is it under the upper so i cant get to it if i dont pull the upper
Moderator
have you pulled the codes? we could help you out more if we knew exactly what code it was throwing.
Moderator
here is a cheap way to pull codes once you do get back with us.
my5oh.com, Your Ford Tech Source • View topic - How to do a Self-Test |
Yes, 160 degree thremostats will throw a check engine light.
98 Cobra
98 Cobra
1 more question, would that cause my engine to run any differently becuase of the 160 degree thermostat?
1986 LX
none yet
It will run a little richer.
98 Cobra
Yes it will be richer across all cylinders. It will probably do more harm than good at high altitudes.
you car will not reach full operating temp, and you will not be driving around in closed loop
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
98 Cobra
alright guys thanx for all the help
1990 LX hatch
Threads Similar to: engine light
| Engine Light?? | cohnhead21 | 2005 - 2010 | 1 | June 23rd, 2008 04:11 PM |
| Engine Light Need Help | 90Stang | 2005 - 2010 | 7 | June 7th, 2008 12:26 AM |
| engine light help! | jat | 2005 - 2010 | 8 | July 11th, 2007 02:15 PM |
| engine light | nyjetsfan4lif3 | V6 Mustangs | 6 | March 13th, 2007 09:17 PM |
| engine light code what is it ? | xxrals22xx | V6 Mustangs | 4 | January 24th, 2007 03:58 PM |
