No engine light?
Old July 27th, 2008, 02:39 AM   #1
1989 Coupe
Titled4cyl is on a distinguished road
No engine light?
Ok this is the deal. I bought a 1993 GT for $1000, the kid said it had an aftermarket cam and rockers and that it had a bent pushrod. The car hasn't started in a long time. So for $1000 I bought the car anyway because the car is in great shape. I get it home put a battery, alternator and an oil change in it. Once I get it started I don't hear any noise in the motor other then a miss and the worst exhaust leak I have ever heard (lol). So I go to the local parts store pick up Exhaust gaskets, and a complete tune up (cap, rotor, plugs, wires and an air filter. Once I get that done I start it again and it still has no power and it hesitates when you hit the throttle along with some small back fires. I was wondering if it could be timing or maybe it still could be a pushrod ext.
Old July 27th, 2008, 02:42 AM   #2
Is the game, Ross is the name.
6DXR's Avatar
1998 M3,2K8 Ninja 250
Faster Than Fapsmith's Asian Girl
6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all
Send a message via AIM to 6DXR
Am I missing something?
Did you fix the bent pushrod? That would be the problem..
I drive a 1998 BMW M3. I used to drive the sexiest Mach 1 in existence. But now I am a 3uroslut
Old July 27th, 2008, 02:51 AM   #3
1989 Coupe
I didn't fix the pushrod because it has no engine noise. I would think it would have a noise in the motor if it had a bent pushrod? I was just going to replace them anyway if everyone thought it could still be the problem.
Old July 27th, 2008, 03:01 AM   #4
6DXR's Avatar
I don't know much about engines, but I would assume that's the issue. Replace that one and see if it changes.
Old July 27th, 2008, 05:38 AM   #5
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
theres a whole slew of problems it could be, but i would check those pushrods before you try and fix anything else.
Threads Similar to: No engine light?
engine light 91cobra5.0 5.0 Mustangs 18 July 28th, 2008 08:09 AM
Engine Light?? cohnhead21 2005 - 2010 1 June 23rd, 2008 04:11 PM
Engine Light Need Help 90Stang 2005 - 2010 7 June 7th, 2008 12:26 AM
engine light help! jat 2005 - 2010 8 July 11th, 2007 02:15 PM
engine light nyjetsfan4lif3 V6 Mustangs 6 March 13th, 2007 09:17 PM
