LinkBack (1) | Thread Tools |
new heads for cheap
is it true that late model 5.0 explorers had gt40 heads??
98 Cobra
if i remember right its 96-2000 that have the 40s and like 2001-2003 that have the 40ps and i dont know what yeat but mountaineers have 40s on them
some one said that the gt40p heads require special headers to clear??
The Razor's Edge
i don't think there special.....but there is something about the headers
98 Cobra
they require special headers becuase the patern is different than stock or just plain the gt40s
The Razor's Edge
oh good luck finding them
98 Cobra
yea ive been hitting up the only good junkyard here in colorado springs for about 5 months and everything they get a v8 explorer in, the engine and driveline are gone
The Razor's Edge
yeah you hear that all the time...damn people and there big mouths lol
junkyard near me had 2 mountaineer v8s last time i went
#10 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Do you get any hp increase with those heads over our stockers??
Military Crew USMC
1988 lx
9.68@142
early 90's have gt40 and 97 1/2 and up have gt40p
and yes you will proly gain about 40hp (crank) from the heads and intake over stock.
1989 LX Vert - 1993 Notch
Fast
The GT-40P iron heads off Explorers are great head.
Flow close to aluminum GT40Y head numbers. The spark plugs mount at a different angle and can have header clearance problems with some headers, most header do clear though
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
The Razor's Edge
sounds to me like an easy way to make some money
1996 to early 1997 V8 Explorers and Mountaineers had GT40 heads. Mid 1997 to 2001 had GT40P heads. The P heads are more desireable and have more performance potential.
Some headers do not work with P heads because of spark plug interference. The spark plug angle is different on P heads which is one of the reasons they make more power. The spark plug is positioned closer to the center of the cylinder. 90 degree boot plug wires help.
#16 | ||
![]() ![]() *deep breath* the GT-40 heads that were found on the 1993-1995 cobras were also found on the 5.8L Lightning, and the 1996-1997.5 Explorers and Mountaineers. The Explorer heads have a larger combustion chamber than the cobra heads, and when bolted onto a stock bottom end, will actually lower the compression ratio slightly. It is always best to have the heads machined down to a 63-64cc chamber before installing them (also makes a nice mating surface to the block) the GT-40P heads were found on the 1997.5-2001 Explorers and Mountaineers. They featured a smaller combustion chamber that, when bolted to a stock bottom end, produced a ~9.5:1 compression ratio. These heads also have the revised spark plug location... but fear not! Most shorty unequal length headers work on GT-40P heads. You will USUALLY have to swap out the spark plug boot on the #7 wire to one with a 90° angle. /rant ok, I feel better now... can we all maybe try to spread GOOD information for once?
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
95 Mustang GT
sounds pretty much exactly like what darell just said but more drawn out and complicated
well i have bbk long tubes will they clear
Possibly. Try and find out.
yea, funny how he posted it AS I was typing...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/82000-new-heads-cheap.html
| new heads for cheap - Page 2 | This thread | Refback | July 30th, 2008 05:18 PM | |
Threads Similar to: new heads for cheap
| crazy cheap heads? | JBIGBOOTSY | 5.0 Mustangs | 4 | March 12th, 2007 07:18 PM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 03:18 PM |
| Cheap Cheap!!! 3.73 gears minor chips... Buy It Now $45 M/O | 00SoSlow | V6 Mustangs | 3 | August 5th, 2006 10:32 AM |
