![]() iTrader: 1 reviews
My current cluch/pressure plate and flywheel...leave comments
The car wouldn't move or go into gear really. The throw out bearing pretty much pulled in two once we got it out, and a metal ring inside it was all bent up, but I figured I'd just remove the clutch and pressure plate while I was at it just to make sure, and here's what they look like.
Flywheel: ![]() ![]() ![]() ![]() ![]() Pressure plate: ![]() ![]() Clutch: ![]() ![]()
I'm sure the throw out bearing was the problem. Everything else looks ok. Make sure the throw out bearing and disc is installed properly.
1992 Lx
11.39@119.24
looks like new!
1995 Mustang GT
Do everything you can while you've got it out. Put in a new teflon felpro rear main seal, new pilot bearing, have the flywheel resurfaced or buy a new one and get yourself a new clutch.
See garage for mods |
It's already got new front and rear main seals in it actually. The motor was just pulled from a car and put into the one I got, so they put a new oil pump, gaskets, timing kit, etc on it while it was out.
I had no idea that stuff looked new, I've never had to replace a clutch before. I thought it all looked like crap from what I thought those parts should look like, but even local guys said it looks like it hadn't even been broken in yet. |
Threads Similar to: My current cluch/pressure plate and flywheel...leave comments
| Torque on pressure plate to flywheel | zinc02GT | 99-04 | 0 | March 27th, 2008 11:35 PM |
| Pressure Plate Bolts 4.6 SOHC | WAR-PARTY | The Clubhouse | 8 | May 31st, 2007 08:18 PM |
| Pressure Plate Bolts 4.6 SOHC | WAR-PARTY | 99-04 | 0 | May 31st, 2007 07:46 PM |
| Pressure Plate Bolts | WAR-PARTY | 99-04 | 0 | May 31st, 2007 07:45 PM |
| cluch pedal ratches | slayer | 5.0 Mustangs | 1 | April 24th, 2007 02:57 PM |
