Heads Change
Old November 20th, 2006, 01:08 AM   #1
95StangSVT's Avatar
95StangSVT is on a distinguished road
Heads Change
my stock heads on my 95 gt are 1.84 /1.54 valves with 60-63cc chambers.im looking at buying brand new fully done set of heads that are 1.94/1.6 61cc ..i want redone heads and i want an upgrade for performance but dont want to change pistons its my everday driver so i was wondering if putting the 1.94/1.6 heads would be worth spending the money as far as performance goes ..i dont want to spend the money on new heads if it wont make a power diffrence ill just have my stock ones redone...help me out thanks
Old November 20th, 2006, 01:14 AM   #2
Justincredible's Avatar
Justincredible is on a distinguished road
Depending on how much your going to spend...
For ~$1000 you can have a set of Trick Flow Twisted Wedge heads with 2.02/1.60 valves that will work with the stock pistons up to .500" lift.
These heads with a matching TFS Stage 1 cam will yield ALOT more bang per buck vs. a set of ported cast iron heads that wont make anywhere near the power as the TFS heads and end up costing about the same in the end.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old November 20th, 2006, 08:41 AM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Spend the extra $ and go aluminum. TFS, AFR, or eddie.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old November 20th, 2006, 09:41 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Stock heads are stock heads. Its not worth it to spend money on bigger valves and/or porting on stock heads. A set of aftermarket heads out of the box will kill any ported factory head.
Old November 24th, 2006, 11:20 AM   #5
coreyfitz is on a distinguished road
heads
I'm looking at putting some new heads on my car what are the best heads to go with on a stock engine, its my daily driver so I don't wanna kill my gas to much and I heard aluminum heads overheat really easily so and advice on what to go with
Old November 24th, 2006, 12:03 PM   #6
woody1 is on a distinguished road
Re: heads
I can think of atleast 3 dozen factory cars that come with aluminum heads in the last 10 years, so what you heard is bad info in regards to aluminum heads
Old November 24th, 2006, 12:17 PM   #7
sometimes I drive the car long distances up to like 300 miles round trip sojust do wanna ruin 1500 dollar heads you know what I mean. Like I said I just heard they overheat so just don't know if I wanna take that chance so just wanted so info
Old November 24th, 2006, 04:25 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Aluminum heads don't over heat. Whoever told you that needs to get his head out of his ass. Damn near everything comes from the factory with aluminum heads these days. They disapate heat much faster than iron which is good. If you can swing it, go with some good aluminum heads. They will be a much better investment with much greater rewards.
Old March 7th, 2007, 06:16 PM   #9
stang boi 91 is on a distinguished road
I have a 540 lift cam tf track heat intake and I think some dish type pistons can I run those tf twisted wedge heads on my car with that lift
Old March 7th, 2007, 06:49 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Probably, but the only way you will know is to check valve to piston clearance........which you should always do when assembling an engine.
Threads Similar to: Heads Change
Heads for a 302/Shifter change keefboz Classic Mustangs 23 October 3rd, 2007 07:58 PM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 10:55 PM
Something has got to change! kobebryant V6 Mustangs 69 April 23rd, 2007 04:30 PM
Easy 400 HP from N/A SBF with Heads & Headers change! Zak 5.0 Mustangs 25 October 3rd, 2006 05:11 PM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 04:18 PM
