funny vibration while accelerating
LinkBack (1) Thread Tools
Old July 29th, 2008, 01:34 AM   1 links from elsewhere to this Post. Click to view. #1
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
alright so on my 88 gt its got a vibration while hard accelerating, its a stock 5.0 with a aod, when ever i get on it, it will start vibrating at about 4000rpms and then stop at about 4500rpms, its definatley in the drive line. basically i would like to know possible causes for this, and i hate to say it but it almost feels like a transmission problem
Old July 29th, 2008, 01:49 AM   #2
1992 Lx
11.39@119.24
driveshaft unbalanced? rear end going out?
Old July 29th, 2008, 01:53 AM   #3
1987 ford mustang gt
well see when shes done
if it was the driveshaft you would feel it at all rpms most likely
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old July 29th, 2008, 09:31 PM   #4
78mach1's Avatar
it only does it during hard acceleration and then it goes away.
Old July 30th, 2008, 12:04 AM   #5
REIGNYC's Avatar
1991 MUSTANG GT
REIGNYC is on a distinguished road
Dude Check Your Exhust Make Sure The Brackets And Welds Are All Connected !!
*WE CAN BUILD IT WE HAVE THE TECHNOLOGY*
Old July 30th, 2008, 02:17 PM   #6
78mach1's Avatar
ya its not that, the exhaust is all new and i have re torqed all the bolts 3 or 4 times. it feels like a drive line issue
im just trying to get this car smoth and buttoned up good cause im thinking of selling it
Old July 30th, 2008, 02:20 PM   #7
baine21225's Avatar
my friend had a similar problem, spark-plugs were bad.....it would shake and then go away......changed them and its like a brand new car
Old July 30th, 2008, 02:28 PM   #8
78mach1's Avatar
im pretty sure it has nothing to do with the engine because it runs smooth the hole time, and i have done a tune up (plugs, wires, cap, rotor)
Old July 30th, 2008, 05:32 PM   #9
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
this may sound stupid but check the driveshaft bolts, i chased a similar vibration for a long time before i realized my bolts were coming loose !
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old July 30th, 2008, 10:54 PM   #10
ujslost's Avatar
Actually thats not a stupid idea. I have seen it happen.
Jack the car up in the rear scotch the front tires. Put the car in gear, dont give it throttle let it idle. You or someone else look under the car and watch the drive shaft see if its bent. And inspect it for dings or missing counter weights.
I had this problem.I swapped the driveshaft out for a known good one, and the vibration was gone. So I bought another shaft. problem solved.
Old July 31st, 2008, 10:20 AM   #11
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Sounds like a driveshaft issue. Check bolts ^ then joints. Also if the bushings are worn out in the control arms, the pinion (front of the gear case) can roll upward enough under hard acceleration to change pinion angle and cause a harmonic type vibration. Improperly set adjustable control arms can do the same thing.
Never fast enough.
Old July 31st, 2008, 01:26 PM   #12
REIGNYC's Avatar
1991 MUSTANG GT
Well DUDE !! when you fix it might as well keep it cause now its new !! LOL !! anyway gl if its not exhust it most deff could be the drive shaft but it could also be the TRANSMISSION CROSS MEMBER who installed it check its BOLTS as well
Old August 2nd, 2008, 11:01 PM   #13
1991 lx
foggyracing is on a distinguished road
a friend had a similar problem and ended up being a u-joint
Old August 3rd, 2008, 12:04 AM   #14
91cobra5.0's Avatar
98 Cobra
are u joints hard to replace in these cars?
Old August 3rd, 2008, 09:48 AM   #15
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
No. Couple hours max including removing the shaft, even less if you have a press or large bench vise. Replace them with Spicer brand, not the cheap Chinese made ones.
Never fast enough.
Old August 3rd, 2008, 10:10 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
I've had that happen numerous times.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/82255-funny-vibration-while-accelerating.html
funny vibration while accelerating This thread Refback February 26th, 2011 01:10 PM
Threads Similar to: funny vibration while accelerating
noise while accelerating Xantho99 99-04 7 February 4th, 2008 06:14 PM
Problems (Idleing) and Accelerating) Darkside_03_GT 99-04 10 December 19th, 2007 06:34 AM
Why does my car keep accelerating? krisp1108 V6 Mustangs 8 September 30th, 2007 01:12 AM
accelerating problem smoke-em 4V / SVT 6 May 22nd, 2007 01:02 PM
Bogging Down While Accelerating dcraig8 5.0 Mustangs 5 October 1st, 2006 03:23 PM
