oil pan swap
Old July 29th, 2008, 10:47 AM   #1
crowbar73's Avatar
1989 Mustang GT
crowbar73 is on a distinguished road
oil pan swap
I need to replace the oil pan on my 89 gt. It is stock and is dented in & leaking where the previous owner hit something? Is it possible to just loosen the motor mounts and jack the motor up a little to replace it or do you pretty much need to take the motor out? Also are the chrome oil pans ok or are they more likely to leak? And last question, do the stiffening plates that go under the bolts work ok or are they a waste of money? thanks for any advice
He is no fool who gives what he cannot keep to gain what he cannot lose." Jim Elliot
Garage: http://www.moddedmustangs.com/forums...-member-10915/
Old July 29th, 2008, 12:31 PM   #2
92sspnotchback is on a distinguished road
I would not put the el cheapo chrome pan on it, i would find a stock pan with the stock rail stiffeners to go back on the car, or order a new one from ford racing for $100. I do not know if you can change it in the car, I am sure someone else will chime in about that.
Old July 29th, 2008, 05:20 PM   #3
1983 mustang lx
83fox is on a distinguished road
im pretty sure you have to pull the motor. i dont think there would be enough room to get the pan out because of the oil pump pickup and the crankshaft.
Old July 29th, 2008, 06:05 PM   #4
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
I pulled mine without pulling the motor. I was changing the gaskets, but I also changed the clutch at the same time. If you haven't changed your clutch in a while you can kill 2 birds with one stone. It probably will be tough to do with the motor in you have to get a lot of clearance.
Old July 30th, 2008, 12:25 AM   #5
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
yeah i have to do the same soon. im just pulling the motor. im also putting on a crank scraper and windage tray.
Threads Similar to: oil pan swap
oil pan rog50stang 99-04 5 April 28th, 2008 09:30 PM
Oil Pan 91 gt 5.0 5.0 Mustangs 3 March 24th, 2008 11:06 PM
Oil Pan 95kystang V6 Mustangs 12 October 8th, 2007 11:37 PM
kickout 7qt oil pan w/low oil sensor hole Iownastang 5.0 Mustangs 2 July 19th, 2007 01:17 AM
Oil Pan Pony_with_an_attitude 5.0 Mustangs 3 March 5th, 2007 07:40 PM
