#21 |
![]() ![]() ![]() ![]() ![]() iTrader: 13 reviews
Is it okay to switch back to conventional after running synthetic for a while?
#22 |
87 Coupe
![]() iTrader: 3 reviews
I'm not sure but I heard you could you just hafta go down to the syn blend for a little then go back to the oil or get it flushed and got to it. Not too sure bout that though cuz I heard synthetic leaves a residual in the cylinders so not too sure how that would work.
Eats rice daily
#23 |
Yes you can. You can even mix synthetic and conventional if you want.
#24 |
ok thanks, good to know
#25 | |
1986 LX
none yet
common misbelief is that 10 40 is much better than 10 30 because its thicker. well actually if you want something thicker stick with a straight 40 weight. actually you have less viscocity range with 10-30 than with 10-40. so in my opinion go with a flat weight synthetic. |
#26 |
theres a post somewhere on these forums that gives access to an online library for cars and stuff. Username Library password Library, dont know if anyone refers to this... but...
i was reading through the articles and stuff on there and i found that ford tested 5w 30 oil and found it to be better than 10w 30. ill try to find where it said this.
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
#27 |
alright i found it. now how do can i get it so you guys can see it? like a website i can upload it to/way to embed it its 143 kb big.
Threads Similar to: Switching to Synthetic - What should i get?
| Safe switching to synthetic oil??? | smokeshow | 99-04 | 5 | February 20th, 2008 05:38 AM |
| Synthetic | blazor | V6 Mustangs | 25 | January 11th, 2008 08:49 AM |
| Synthetic | Youngin | V6 Mustangs | 43 | August 31st, 2007 11:02 AM |
| conventional to synthetic | WilltheThrill | 99-04 | 18 | August 23rd, 2007 09:30 PM |
| Synthetic vs. semi synthetic vs. standard | stagecrewgod | General Tech | 2 | March 29th, 2007 09:33 AM |
