Discussing bought a car in the 5.0 Mustangs Forum. hey guys so i bought a 91 GT monday and this is what i got, ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
bought a car
hey guys so i bought a 91 GT monday and this is what i got, ugly ass 4-spoke pacer rims, flowmaster 40s, performace products upper and lower and throttle body(all 3 polished) a second rate paint job(the guys had good intentions, just looked like they didnt take there time on it) its an automatic stock gearing. the guy "claimed" the motor only has 12000 miles on the motor which he might be right bc the motor is extremely clean for being stock. ok so 2 small questions, 1.)he has bosch platinum 2's in it and has a rough idle' almost stalls, could the plugs be it? 2.) the tranny shifts way to soon almost feels like it races to the final drive, what could it be? -thanks in advance!-
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
If one or more of the plugs or wires is bad then they might cause a rough idle. I'd give it a tune up since the car is new to you.
As far as the tranny problem, I'm not sure. Its hard to diagnose something like that over the internet.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Is it possible he just has a really agressive cam Darrell? Or more than likely no? Mine has a really rough idle but now that ya say this maybe i should check mine heh.
i think thats just the AOD because mine does that to, but it drives well and is extremly smooth
![]() In Memory of Nick Goris. |
is it still speed density?...because if it has a new cam in it, its probably not going to work properly
#6 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Probably not. Its pretty obvious if the cam isn't stock.
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Its a 91GT so it is a mass air car.
1989 Mustang LX
10.98@126.7 NA
Check TV cable adjustment on trans Ford AOD Transmission :fordpower
Never fast enough.
when i bought the car the guy, right in front of me, swithed the mass air from some small restrictive mass air to a 65mm. i dont know why he did he just did it. and i also put msd 8mm wires on it yesterday and it still idles rough and definetly no wild cam in it.
#10 | |
yea the tv cable is adjusted is there any other option?
1989 Mustang GT
is it the one in the pic?
1986 Mustang GT
could it be that the new maf is not calibrated for the stock 19# injectors and it's making it idle/run rough?
MILITARY CREW
AT2 |
no its not the one in the pic. and how do i calibrate the mass air?
1988 mustang gt
check the alternator will idle rough or stall not putting out enough amps
hey im back, ok TV cable is adjusted, plugs and wires just put them on, timing is mint, but i think i found the problem(maybe) i replaced the plugs anf they were black as the ace of spades(and they were bosch platinum 2's) i replaced them with autolites and 8mm wires, as i was finishing, i noticed the cap was moving, i pulled up on it and where the cap clamps down, that part was tight but where the plastic ends it lifts up and down, now i know thats not good at all but could that be my problem? oh and also i replaced the plugs and it smokes a lil bit but i think it might be the timing too. im really stuck here so if you help i greatly appreciate it.
BLWN91GT
Hey, Well back when I had my 94GT, I had a rough idle and it sounded like it had a decent cam in it. 5.0s Have tons of vacuum lines. Check your upper/lower intake for an unplugged vacuum line. Mine was the PCV hose was unplugged. Are you throwing a check engine light?. Check those hoses. I almost guarante thats the case.
PaT #06 |
Im confused. You said the timing was mint. Then said that it smokes and you think it cause of the timing.
If its smoking and the plugs were black it sounds like your running rich as hell and fouling plugs. You might have a stuck injector or fuel pressure regulator bad. Also that PCV he spoke of is notorious on the efi 5.0s for coming out of the intake. |
Badass Mother 3000
Twice as fast as your ass!
Replace that distributor cap, could be the problem. What's the timing set at? And define rough idle. Is it choppy or does is roll? If it rolls or dips low it could be the TPS.
MM Pirate Crew CAP'N PARTS FOR SALE Cobra 70mm MAF Eaton M90 |
the timing WAS good but i checked it again a couple days later and noticed the plastis was moving up and down, so it may not be good anymore. the idle does dip and stalls sometimes. im going to replace the distributor here soon ill keep you posted
thanks guys i appreciate it |
Threads Similar to: bought a car
| i bought a project car | BWAL09 | The Clubhouse | 55 | May 9th, 2008 09:58 AM |
| Hay Everyone Who Bought A Car From This Company You Might Want To Get A Lawyer! | wrksnfx | Feedback Forum | 6 | April 2nd, 2008 02:32 AM |
| Bought my first car | My First Ride | 5.0 Mustangs | 10 | March 13th, 2008 05:34 AM |
| I bought a new car | WAR-PARTY | The Clubhouse | 8 | February 28th, 2008 02:30 PM |
| bought a new car (z28) | GTblackprodigy | The Clubhouse | 69 | September 10th, 2007 09:19 PM |
