water pump replace
im trying to take off the housing that the water pump connects to. i got a 5.0 88 gt
i took off 13 screws which is all that was needed to take off but the housing still wont come off. any suggestions? |
1988 Mustang GT
N/A
Probably stuck on with rtv sealant, just needs a little prying off. Looking in the Haynes manual now and it doesnt say exactly how many bolts.
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"! |
87 Mustang GT T-top
i would first make sure all the screws are off. try to get it off again, if no luck there i would use a rubber mallet and give it a few love taps. But dont kill it, it might break off pritty easy. But if your replacing it with a new one i guess if your angry and want it off now, it wont really matter what it looks like after ya beat the crap out of it. Especially if ya got a new one
![]() But if you do find out that there was rtv sealant i would put some on the new one as well. Btw did ya get a stock replacement or a bigger aftermarket water pump? Anyways Good luck! |
its jut a replacemnt. but i failed to also say that a screw broke off and its only in the water pump housing but its bent so could that prevent it from coming off?
98 Cobra
pry the water pump off carfully, try and pull it straight off if possible, then grab that broke bolt with a pair of vice grips and try and get it out, i would highly recomend using a can of PB blaster to loosen up rust and help break it free
Threads Similar to: water pump replace
| Water Pump | rainier446 | 99-04 | 14 | April 17th, 2008 10:13 AM |
| pt 2. water pump | Rustbelt | 5.0 Mustangs | 2 | February 3rd, 2008 12:18 PM |
| Water Pump | Badasstang281 | 99-04 | 2 | December 27th, 2007 05:40 PM |
| Water pump | 90Stang | 5.0 Mustangs | 13 | July 8th, 2007 04:57 PM |
| Water pump ??? | Fastback GT | Classic Mustangs | 15 | February 24th, 2007 02:37 PM |
