need help getting off front rotors
Old August 1st, 2008, 04:17 PM   #1
91cobra5.0's Avatar
94 GT
every other car that ive done braks on the front rotor just slides off, whats the deal with these ones?
94 GT - Deep Forest Green
Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block
Old August 1st, 2008, 04:26 PM   #2
87 Mustang GT T-top
The Novice is on a distinguished road
got pictures, is ther a lot of rust? It might just be rusted stuck. try giving it a few love taps.
Old August 1st, 2008, 04:37 PM   #3
91cobra5.0's Avatar
94 GT
i tapped it a little but it still didnt budge, i didnt want to hit it too hard i dont have a plastic hammer, ill get pics in a few secs, ima google it
Old August 1st, 2008, 04:46 PM   #4
91cobra5.0's Avatar
94 GT
Old August 1st, 2008, 04:57 PM   #5
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
Beat it.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old August 1st, 2008, 05:07 PM   #6
87 Mustang GT T-top
Well the only thing i can think of is that on my DD car, the rotors on that car have these little washers that screw on and are very thin but are made to hold the rotor tightly in place, if ya dont see those i would assume that its just rust.
If ya need to try a little WD-40,get a wire brush, brush them a little and see if ya cant get them off that ways.
But from here those bolts look like they are pacticially welded on to that rotor so it might take a little muscle to break it loose.
Old August 1st, 2008, 07:09 PM   #7
91cobra5.0's Avatar
94 GT
i figured it out, i pulled off that big grease cap and you have to unscrew the nut holding the rotor onto the spindle and pull out the bearing and the rotor slides off
Old August 1st, 2008, 07:13 PM   #8
87 Mustang GT T-top
Ok cool, sorry i couldnt help more. Did ya end up getting the drilled performance rotors? If ya get a chance take a pic sometime when your done, im sure they'll look cool
Old August 1st, 2008, 07:20 PM   #9
Hunt_chevs's Avatar
2002 Gt
Not Slow
, i was about to tell you to do that when i read through to your post
Old August 1st, 2008, 09:05 PM   #10
nolife's Avatar
91GT, 88GT, 02GT
You did buy new bearings right? Another note, there is a very specific method and torque requirement for putting that "big nut" and cotter pin back on when your done. I don't have a Chiltons with me but the AutoZone site has the instructions. Basically, torque it to a certain in/lb while spinning the rotor and then loosen and torque to something else + like 1/4 turn or something similar to that. You really should read it because you will have rotor/bearing problems if you try some random method.
Old August 2nd, 2008, 01:07 AM   #11
ryans88gt's Avatar
tighten fairly tight like 10-15 ft lbs. back off a 1/4 turn, tighten to 20 in/lbs I think.
Old August 2nd, 2008, 02:08 AM   #12
91cobra5.0's Avatar
94 GT
no i didnt, i figured i dont need em , im just driving around town not road racing so i figured id spend the money else were
Old August 2nd, 2008, 11:49 AM   #13
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
Old August 2nd, 2008, 02:13 PM   #14
REIGNYC's Avatar
1991 MUSTANG GT
REIGNYC is on a distinguished road
I Did Not Read The Other Post But On Mustangs The Center Part Of The Rotor Is A Grease Cap That You Can Get Off With A Flat Screwdriver Clean Out Some Of The Grease Unfold The Center Pin That Is There And Take Off The Lock Nut Then Pull Out The Rotor>> Dont Forget To Change Your Ball Berrings And Seals When You Do A New Rotor Job You Can Get Away With Keeping The Old Bearings But Since You Race Your Car I Wouldent Take A Chance On Keeping The Old Part
*WE CAN BUILD IT WE HAVE THE TECHNOLOGY*
Old August 3rd, 2008, 04:41 PM   #15
78mach1's Avatar
ya basically just take your time, use a new cottor pin and make sure you pack your new bearings!
Old August 3rd, 2008, 05:31 PM   #16
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
be careful with drilled rotors. I had them on my old maxima and my fox and on both cars the rotors crack at all the holes. I'll post up pics tomorrow.
Old August 4th, 2008, 12:07 AM   #17
MCRPARTS.COM is on a distinguished road
Man I wish I saw this earlier.I got scared when some one said to beat the rotor off LOL
Glad to see you figured it out. The slotted rotors are nice,they clean off,cool better than the stock ones too.
It any of you guys get into a jam,feel free to call the toll free # during normal business hours.I could have helped you right away with this.
Tony
http://www.MCRPARTS.com
Muscle Car Restoration Parts
Specializing In Ford Mustang Restoration
CALL TOLL FREE 1-877-878-5890
OPEN M-F 9-5 EASTERN TIME
Old August 4th, 2008, 01:09 AM   #18
91cobra5.0's Avatar
94 GT
Tony
thanks for the offer ill have to make sure i write it down
Threads Similar to: need help getting off front rotors
Front Rotors silverstang 2005 - 2010 22 June 30th, 2008 02:57 PM
whats is the size of the stock 2001 gt Front/Rear Rotors RanGer498 99-04 1 February 27th, 2008 07:32 PM
Removing Front Brake Rotors OcOnnor220 99-04 3 August 4th, 2007 06:51 PM
