1988 mustang LX coupe
TFTW heads
ok so I have a set of trickflow twisted wedge heads with the 1.6rr
am I going to have any clearance issues with pistons or anything?
89GTcoupe- 304ci, tfs1cam, tftw heads, 2.5"flowies, GT40intake, TF23lb inj, t5 w CFDF, SN5bolt, 3.73gears, GTkit, Y2K R wing, 17" Tribars 88coupe- lookin for a new powerplant |
Only if you step up to a high lift camshaft.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
is the tfs1 good enough?
1989 LX Vert - 1993 Notch
Fast
Max valve lift has NOTHING to do with piston to valve clearance
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
1982 GT t-top
no proof of purchase
the TW heads move the valves around so you can put them on a stock block
ok sweet... so I'm guessing the street heat heads are the ones that have clearance issues?
Depends on what cam you use. Most mild cams work fine with Twisted Wedge heads but always check valve to piston clearance.
+1
Valve timing events place the the valves in the way of the pistons.
Threads Similar to: TFTW heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 09:01 PM |
| Are PI Heads better than milling my heads | 96redGT | 96-98 | 7 | April 30th, 2008 04:10 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 09:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 09:55 PM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 03:18 PM |
