Aluminum flywheel Question/request
Old August 2nd, 2008, 07:00 PM   #1
1994, mustang gt
N/A
izze01 is on a distinguished road
Send a message via AIM to izze01
I have a Fidanza in the car now (stock 5 liter) in the next few weeks the 347 gets a new home in the car. Thing is the aluminum flywheel has a 50 ounce balance (removable weight) the 347 is a offset ground stock 351 crank which is a 28 ounce balance.....I need a weight, will Fidanza sell a weight or does someone have one laying around.
Also is the 50 ounce really perfectly 50 ounce cause I do have a friend that has a CNC mill in his garage and he can just machine some off until the 28 ounce is acheived.
Old August 2nd, 2008, 07:13 PM   #2
demonicus's Avatar
1988 mustang LX coupe
demonicus is on a distinguished road
throw it on a scale and find out... and wouldn't you need to set the 28weight on the offset for the 351 crank? if you've changed the balance of the crank from stock then the weight should be changed too shouldn't it?
89GTcoupe- 304ci, tfs1cam, tftw heads, 2.5"flowies, GT40intake, TF23lb inj, t5 w CFDF, SN5bolt, 3.73gears, GTkit, Y2K R wing, 17" Tribars
88coupe- lookin for a new powerplant
Old August 2nd, 2008, 07:30 PM   #3
1989 LX coupe 5.0L
89lx is on a distinguished road
when you bought the flywheel you should have gotten both 28 n 50
Old August 2nd, 2008, 07:48 PM   #4
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
im gonna say you can have your friend mill it down to 28 oz and it will work
Old August 2nd, 2008, 07:54 PM   #5
1994, mustang gt
N/A
I got the fly wheel from a buddy of mine and he had the 302 so god knows where the weight went, My buddy with the mill can probably get it within an gram but i was just wondering if anyone knew if it is absolutely perfect.
Old August 3rd, 2008, 04:18 AM   #6
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
I wouldnt mill it if I were you... contact the flywheel manufaturor before you do ANYTHING.
and it will need to be spun on a balancer to determine true center for the offset, before you can remove any weight
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old August 3rd, 2008, 10:18 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You are getting this new 347 balanced aren't you? Use the 50 oz weight and let the machine shop take however much weight off as necessary to get the rotating assembly to balance. Chances are you won't need a 50 oz or 28 oz when they balance it. Every assembly I've had balanced has had the weight ground down no matter how many ounces it was originally.
Threads Similar to: Aluminum flywheel Question/request
aluminum flywheel Ticket-Me-Yellow V6 Mustangs 11 June 22nd, 2008 11:32 PM
aluminum flywheel tom2000r 99-04 6 March 15th, 2008 01:06 AM
Aluminum Flywheel itschristorres8 Parts 2 January 27th, 2008 10:39 PM
Aluminum Flywheel? Badasstang281 99-04 28 December 11th, 2007 03:43 PM
Aluminum Flywheel? Horseshoeing Classic Mustangs 7 July 28th, 2006 06:58 PM
