1991 MUSTANG GT
Electric Water Pump...
HEY LOOKIN TO GET AN ELECTRIC WATER PUMP AND AN ELECTRIC FAN DOES ANYONE KNOW IF THESE ITEMS WILL CONNECT TO AN ACCELL DFI CPU ?? IM LOOKIN TO GO WITH MEZZEAR WATER PUMP WHAT U THINK ?? AND AS FAR AS THE FAN WHAT IS THE BEST TO GET AS AN ELECTRIC TO FIT 91 GT I HEARD THAT 94-95 MUSTANG FAN WOULD BE BEST BUT NOT SURE GONNA CHANGE THE RADIATOR AS WELL WHAT ABOUT THAT AS WELL WHAT KIND IM PUSHIN 650 hp and 500 to THE REAR
*WE CAN BUILD IT WE HAVE THE TECHNOLOGY* |
1979 mustang 5.0
hopefully 11's when complete
typing in all caps is considered yelling on the internet......... fyi
is this car a daily driver or a street/strip car........
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO |
1991 MUSTANG GT
well i go to car shows with it and sometimes take it out to mess around but thats about it dident know about the caps thing thanks
#4 | |
Speaking of horsepower, what is your set up and where did you dyno it? You seem to be losing alot of power thru the drivetrain.
Hey Man, I just recently picked up a BIG END 31" 3core Aluminum Radiator for $189.99. I also picked up Flexlite 210/220 Dual 12" Electric Fans. $220.00. Lastly picked up a Nice Aluminum Catch Can and my car runs cool as Hell now. If your throwing down that much HP, I would def. invest into a nice cooling system. What ever you do dont ever buy a BECOOL radiator. They are nice but both sides are plasic and are crap.
PaT #06 |
No need for more than a single row when using aluminum. I don't think I've ever seen an aluminum that was a three row. Aluminum disapates heat alot better and having a thinner radiator increase airflow thru it.
That's because you don't use dirt track radiators.
![]() Most dirt track parts supply places will carry the 3 row for the high performance 4 cylinders believe it or not. We can't even run a 2 row in ours without them hitting 240.
You haven't failed until you stop trying. |
#8 | |
1990 LX hatch
Wow. Do 4 cylinders run that much hotter than V8s? Or is it more relative to the dirt track? My buddy road races all over the country (Willow Springs, Road America, etc) and he runs a single row aluminum in his car. He said with the oil cooler and power steering cooler in front a thicker radiator would make the car run hot due to lack of airflow thru it.
Yeah man the high performance 4 cylinder cars never get enough speed to really have good air flow so we run dual fans, 3 row aluminum radiators and 160 thermostat. Going in circles never made since to me but it's fun as hell.
Cool. I learn something new every day.
1991 MUSTANG GT
hey have not logged in for a while ill get you the dyno spec and let you know thanks
#13 | |
1990 mustang gt
eventually
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
Threads Similar to: Electric Water Pump...
| Electric water pump | JStang14 | 99-04 | 8 | January 15th, 2008 08:37 AM |
| electric water pump | Newtgadget | 5.0 Mustangs | 12 | October 29th, 2007 11:06 PM |
| electric water pump and fan | notsoslow50 | 5.0 Mustangs | 17 | September 9th, 2007 05:12 PM |
| Electric water pump | MySallyMI | 99-04 | 16 | March 1st, 2007 11:58 PM |
| Electric Water Pump | MyBloodRunsBlue | 99-04 | 16 | January 27th, 2007 09:10 PM |
