Crank but no start
Old August 2nd, 2008, 08:51 PM   #1
817B!GT3X is on a distinguished road
Crank but no start
My car cranks but it don't start. There isn't anypower to the sparkplugs or the Distribuitor. Everything else works,what could be the problem?
Old August 2nd, 2008, 10:07 PM   #2
Anyone??
Old August 2nd, 2008, 10:54 PM   #3
91cobra5.0's Avatar
98 Cobra
are you getting power to the ignigtion coil, also are you getting power to the starter solenoid?
Old August 2nd, 2008, 11:08 PM   #4
Yup! I've got a MSD 6A Box hooked up with a MSD Blaster Coil.
Old August 2nd, 2008, 11:20 PM   #5
Also got all ground cables checked.
Old August 3rd, 2008, 07:42 AM   #6
turbodgumby's Avatar
95 Lightning-Twin Turbo
10.66@126
turbodgumby is on a distinguished road
do you have fuel to the motor, does it have spark(check from plug wire)
'95 Lightning-842rwhp/936rwtrq pumpgas
Twin T-70 Turbos
393w stroker(stock block)
TFS CNC heads
Cam Motion Custom Grind Hyd Roller cam
BBRC EFI Spyder intake
FAST
Stock 185,000 trans(PI3000 converter,PUNISHER VB)
Drag Radials always
Old August 3rd, 2008, 10:10 AM   #7
Yes I have fuel to motor I put gas on the Throttle body to intake,and it still doesn't start. I checked plug and wire and still no Spark
Old August 3rd, 2008, 10:15 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'm would look at the wiring. I've seen people wire up MSD boxes wrong on EFI Mustangs many times. Hook the stock ignition back up.
Old August 3rd, 2008, 10:27 AM   #9
I followed the instructions so it can't be that. Could it be a bad Distributor or igniton Module?
Old August 3rd, 2008, 10:32 AM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No offense but everybody follows the instructions yet people still screw up. You are human, you make mistakes. Double check everything to verify that it is wired properly and make sure you fully understand the instructions. I would also bypass the MSD and try it with just the stock ignition. Honestly that MSD is not going to do anything for you anyway on a stock or mildly modified Mustang.
Old August 3rd, 2008, 11:05 AM   #11
10.66@126
MSD boxes are pretty notorious for going out. I agree you should try by-passing the box and trying the stock ignition before buying anything.
Twin T-70 Turbos
TFS CNC heads
FAST
Drag Radials always
Old August 3rd, 2008, 12:03 PM   #12
I've tried with the STock igniton and still no Spark
Old August 4th, 2008, 09:52 PM   #13
the problem was the Ignition Module.
Old August 4th, 2008, 09:55 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Good deal. Glad you got it fixed.
Threads Similar to: Crank but no start
crank??? 88 t-bird 2.3 Mustangs 0 March 31st, 2008 08:42 AM
crank mpboy 99-04 1 February 20th, 2008 04:24 AM
Crank Fast98stang 96-98 7 January 7th, 2008 05:17 PM
no start no crank no nothing cali 5.0 5.0 Mustangs 14 June 19th, 2007 01:13 PM
crank ? 86gt5liter 5.0 Mustangs 3 December 14th, 2006 06:14 PM
