tubular k-member concerns
Old August 3rd, 2008, 12:12 AM   #1
1991 lx
foggyracing is on a distinguished road
just installed aje's k-member and a-arms. as i was bolting the a-arms on the rear bushing(closet to the fire wall)was sliding forward the more i wrenched. i have not given the bolts a final torque yet because i'm uncomfortable with the looks of the bushing sticking out about an inch or so. has any one else seen this? is this correct? should i be concerned?
Old August 3rd, 2008, 12:34 AM   #2
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
Mine did same thing.
I just went and bought some big 1/2" flat washers to stick in there.
1 or 2 on each side as needed worked fine.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old August 3rd, 2008, 11:25 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is how it is designed. The bushings compress to the control arms when you tighten the bolt.
Old August 3rd, 2008, 12:59 PM   #4
1991 lx
should i install washers or leave it be?
Old August 3rd, 2008, 01:14 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Leave it, that is how it is designed.
Old August 3rd, 2008, 05:31 PM   #6
1991 lx
thanks for the help
Threads Similar to: tubular k-member concerns
MM member concerns JASonic The Clubhouse 43 July 17th, 2008 12:05 PM
GMS Mustang Tubular K member Kit w/ A-arms, K member, & 94GTD1SC Drag 1 November 16th, 2007 01:11 AM
Tubular K-member kit acmillr 99-04 28 August 21st, 2007 02:06 PM
Is a Tubular k member a must? caintcatchmyGT General Tech 9 August 3rd, 2007 12:29 PM
Tubular K Member Install droppedbass87 General Tech 27 October 15th, 2006 05:31 PM
