Question about C4 transmissions.....
Old August 3rd, 2008, 08:08 AM   #1
88stangGT is on a distinguished road
i want a c4 trans for my soon to be turbo 89 GT. now some people where saying i would need to make a certain amount of horsepower to leave off the transbrake with such low of a gear (3.27). is this correct and if so why? my car will be making around 400-450hp. should i get the transbrake. or should i get one without and leave off foot brake. 3000 stall convertor... please give me your opnions..
Old August 3rd, 2008, 09:45 AM   #2
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
I don't see any great advantage for you to spend the extra money on the trans brake. With that gear and stall, foot braking will work better.
Never fast enough.
Old August 3rd, 2008, 10:12 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why such a tight gear? A transbrake will work fine but with that low of horsepower and that tight of a gear the car is going to be a turd off the line whether you have a transbrake or not.
Old August 3rd, 2008, 12:19 PM   #4
the car is going to have a turbo... alot of people with them have 355 in the rear and are running out be4 the 1320. with a 327 you will have enough room. and you can also drive it on the streets alot easier and the highway.. not really looking for a dedicated 1/4 mile car. still drive it around all the time.
Old August 3rd, 2008, 07:03 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Having a turbo doesn't matter. The rpm range and mph at the end of the track is what is going to dictate what gear you need. Assuming you will really make 400-450hp and your car is average weight (3200 pounds with you in it) it should run in the 11.80 area at around 118 mph. Assuming a 26 inch tall tire, with a 3.27 gear that is about 5000 rpm at the end of the track. With a 3.73 gear it will be around 5700 rpm at the end of the track. With a 4.10 gear it will be around 6300 at the end of the track. I seriously doubt your engine will be out of steam by 5000 rpm if it makes the horsepower you are looking for. Street driving won't be any worse with more gear but highway driving will be noisier with no overdrive and deeper gears. 3.27s will put you around 2600rpm at 60mph and 3.73s will put you around 2900rpm.
Have you considered an AOD and a deeper gear? That will give you the best of both worlds.
Old August 3rd, 2008, 07:45 PM   #6
JBIGBOOTSY's Avatar
1990 LX hatch
You are right Darrell, but some turbo guys praise, and swear by the taller gears.
Old August 3rd, 2008, 08:00 PM   #7
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
if it's not a dedicated drag car then i don't see a need to spend the money on a brake, after all using one on the street will only result in massive wheelspin, so i say practice footbraking
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old August 3rd, 2008, 11:02 PM   #8
1990 Mustang GT
13.64 @ 101 MPH
GoodOleBoyzRacin is on a distinguished road
footbrake will be fine fer you. you just wont get the full advertised flash on the stall it will be prolly more around 2850-2900. dont know much about transbrakes. never worried with them
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8
Old August 4th, 2008, 12:50 AM   #9
im not really looking for a all out 1/4 mile car i want to go to the track run it see wat it does and then just drive it around.. drove my friends car tonite c4 355 gears supercharged on the highway wasn't bad at all......
Old August 4th, 2008, 07:13 AM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If the converter does 3000 on the transbrake it will probably only see 2000-2200 on the foot brake. I agree that he doesn't need one, especially after he made it sound like he isn't going to race much and it is going to be more of a driver than anything. Transbrakes are useless on the street.
Old August 4th, 2008, 10:13 AM   #11
well its gunna b a street car.. drive it around mess around with other cars.. all in all it should be ok...
Old August 4th, 2008, 05:37 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Skip the transbrake and put that money somewhere else then. I'd strongly consider a well built AOD and a little bit deeper gear for a street car. It will give you better acceleration and also the overdrive gear for low rpm cruising speeds. Just something to consider.
Old August 4th, 2008, 05:47 PM   #13
the money for a c4 and a good aod is alot diffrent...
Old August 4th, 2008, 06:19 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I guess it depends on what you consider alot. The difference between an AOD and C4 from PA is $350. I'm sure if you found a good local transmission shop that has experience with AOD transmissions you could save a few more dollars.
Old August 5th, 2008, 03:06 AM   #15
im gettin a c4 built to handle 600hp for less then 1g. thats fresh rebuild with kevlar bands, reverse manul valve body and 300m input shaft...
Threads Similar to: Question about C4 transmissions.....
transmissions bluemustang04 99-04 0 March 6th, 2008 05:52 PM
Transmissions flattusmaximus78 V6 Mustangs 3 August 22nd, 2007 12:23 AM
A question about transmissions!! i need advice!!! redree69 5.0 Mustangs 3 March 22nd, 2007 03:23 PM
Transmissions jtillery 5.0 Mustangs 35 March 19th, 2007 08:42 PM
new 98 stang. question about automatic transmissions ^_^ lolfast V6 Mustangs 17 March 14th, 2007 11:51 PM
