Can i boost with 30psi oil pressure?
Just need to know if its safe for now to add a supercharger to my 5.0 thats only reading 30psi of oil pressure at 2k rpm?
1988 lx
9.68@142
i would first get a different gauge and try that it the heat of the day here in az at 2k rpm i have 60psi 45 at idle
1986 lx notch
9.98 @ 135
10 psi per 1000 rpms is all the you need, however i like to see a little more then that, does the pressure go up as your rpm's increase ?
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
The pressure at 2000 rpm really means nothing unless you are making peak power at that rpm. I always plan for 10psi per 100 horsepower.
Threads Similar to: Can i boost with 30psi oil pressure?
| How to install fuel pressure and boost gauge?? | Saleenssc14 | 2.3 Mustangs | 19 | July 22nd, 2008 11:48 PM |
| Oil Pressure | sstang | 99-04 | 2 | March 16th, 2008 06:00 PM |
| Fuel Pressure vs Boost | wolffer | 96-98 | 1 | March 19th, 2007 07:56 PM |
| oil pressure | turp | V6 Mustangs | 1 | August 19th, 2006 11:59 AM |
