Flywheel question???
Old August 3rd, 2008, 12:22 PM   #1
88 Lx
Baker is on a distinguished road
Question
I just send my transmission to get repaired and i now see the flywheel. I'm wondering if i should change it or not. I was looking on ebay for lightweight flywheel (13lbs). if i put on the lightweight flywheel, do i have to change my clutch?? Can i keep my stock clutch? Would putting on a lightweight flywheel be a good modd??
Old August 3rd, 2008, 01:58 PM   #2
sn94's Avatar
BLWN91GT
sn94 is on a distinguished road
iTrader: -1 reviews
Send a message via AIM to sn94
Well to me, its an oppertune time to pick up a nice clutch and lightweight flywheel. I would consider doing it now just for the shear fact that the trans its already out and its pretty easy to install. I would tell ya what kind of clutch to pick up but im not sure on your mods/plans with the car. Spec and Centerforce make sum bad a$$ clutches. Give us some more info on ur pony.
PaT #06
Old August 3rd, 2008, 02:09 PM   #3
88 Lx
its pretty much stock. Ive got BBK ceramic headers,BBk cold air intake,X-pipe, gear 3.73 thats about it . it a Lx 88 changed into a 5.0L (engine 1992 HO).
Old August 3rd, 2008, 02:11 PM   #4
88 Lx
Old August 3rd, 2008, 02:58 PM   #5
TurboLX's Avatar
1988 Mustang LX Turbo
is it a 10" flywheel?
Old August 3rd, 2008, 04:09 PM   #6
88 Lx
ish....i dont know :S i thought they were all the same .....
Old August 5th, 2008, 11:04 PM   #7
BUGMAN's Avatar
BUGMAN is on a distinguished road
With those mods I would have the flywheel turned, install a new clutch and put it back together. If your clutch looks ok then don't even turn the flywheel and just put it back together. Use your money somewhere else that will make a bigger difference.
Not trying to be a smartazz at all so don't take me the wrong way.
Have any pictures of the clutch disc by any chance?
You haven't failed until you stop trying.
Old August 7th, 2008, 08:49 AM   #8
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Just have it turned, costs around $25 at any good auto parts store with the equipment or machine shop.
Never fast enough.
Threads Similar to: Flywheel question???
Aluminum flywheel Question/request izze01 5.0 Mustangs 6 August 3rd, 2008 10:18 AM
flywheel help... terribleonexx88 5.0 Mustangs 4 May 1st, 2008 08:46 AM
flywheel question... fastford3388 5.0 Mustangs 15 April 22nd, 2008 07:15 PM
Flywheel? gregkelley 5.0 Mustangs 24 March 17th, 2007 05:19 PM
Flywheel/Balancer Question 5-0stank 5.0 Mustangs 8 February 23rd, 2007 10:01 PM
